29657 Discussions
Managed Debugging Assistant PInvokeStackImbalance
CharlieG
I'm starting to use Visual Studio 2010 and Intel Visual Fortran Composer XE 2011 on an existing code base. I'm getting an error that I haven't seen before:
Managed Debugging Assistant 'PInvokeStackImbalance' has detected a problem in '...\\FCCMod.exe'. Additional Information: A call to PInvoke function 'FCCMod!FCCMod.clsFCCDll::FCCMod' has unbalanced the stack. This is likely because the managed PInvoke signature does not match the unmanaged target signature. Check that the calling convention and parameters of the PInvoke signature match the target unmanged signature.
Seems like they're trying to tell me what the problem is but I'm not a knowledgable enough programmer to understand the message. If anyone could help me out I'd appreciate it.
My Visual Basic Code:
Public Class clsFCCDll
'FCC Model connections
Public Declare Sub FCCMod Lib "FCCmod.dll" Alias "FCCMod" (ByVal CommonUserDataPath As String, ByVal ExePath As String)
Public Sub FCCModel(ByVal CommonUserDataPath As String, ByVal ExePath As String)
FCCMod(CommonUserDataPath, ExePath)
End Sub
End Class
My Visual Fortran Code:
!DEC$NOFREEFORM
subroutine FCCMod(strUserAppPath, strExePath)
!DEC$ATTRIBUTES ALIAS:'FCCMod'::FCCMod
!DEC$ATTRIBUTES DLLEXPORT :: FCCMod
use IFCOM
use IFCOMTY
use IFWIN
CHARACTER(256), INTENT(IN) :: strUserAppPath
!DEC$ ATTRIBUTES REFERENCE :: strUserAppPath
CHARACTER(256), INTENT(IN) :: strExePath
!DEC$ ATTRIBUTES REFERENCE :: strExePath
status = AllocConsole()
ILEN = INDEX(strUserAppPath,CHAR(0)) - 1
UserAppPath = strUserAppPath(1:ILEN)
ILEN = INDEX(strExePath,CHAR(0)) - 1
ExePath = strExePath(1:ILEN)
And much more...
Wendy_Doerner__Intel
Valued Contributor I
Charlie,
Thanks for posting your code.
The unbalanced stack error was caused by the incorrect calling convention of the fortran subroutine.The VB code assumes the subroutine cleans up the stack when returning; however, the default calling convention of Fortran requires the caller clean up the stack. Then the runtime system detected the mis-matched stack pointer before/after the call. To fix this, please
Change the subroutine to STDCALL like:
!DEC$ATTRIBUTES DLLEXPORT,STDCALL :: FCCMod
For reference:
http://support.microsoft.com/kb/153586
The Mixed Language section of the IntelVIsual Compiler documentation
Wendy
Attaching or including files in a post
One change in the Intel Visual Fortran Compiler 2011 is that strings are no longer null terminated (they were by chance in previous releases). Fortran expects this, but Basic does not generate null terminated strings so you may need to add null at the end of strings you are passing to Fortran.
Wendy
CharlieG
I tried concatenating a CHR(0) to the end of my strings in VB before passing them to Fortran but it did not fix the error.
strohhaecker
Can you please elaborate on this? As I understood, it's the other way round, older versions zero-padded the Fortran strings so passing them to C-style routines wasworking (by accident), but the 12.x release may not "terminate" the Fortran string with a zero character so requires user interaction.
There was a case where a user program was relying on a character variable being followed by a NUL, which sometimes was the case in version 11.1 but much less so in version 12. However, I don't think VB uses NUL-terminated strings. Either it passes a BSTRING descriptor (which requires calling routines to create and read in Fortran) or it passes just the data with no length.
I think we would need a reproducing test case or more detail on the error message to give you any more help. It does look like the error message is trying to mark a disconnect between your call to DLL so I would like at the parameters you are passing to see if they are in format your called procedure is expecting.
Wendy
CharlieG
Here's a test case that reproduces the error.
Charlie
Charlie,
For reference:
Wendy
CharlieG
That did it. Thanks for the help.
onkelhotte
New Contributor II
Had the same problem with WPF and a Fortran DLL.
That didnt happen with Windows Forms and the same DLL though...
Now I will have a nice weekend :-)
Markus
