29376 Discussions
Problems with Quickwin Library on upgradt from 11.0 to 11.1 and on 64bit system
schuerg
We are using Microsoft Visual Studio 2008 with Intel Visual Fortran compiler 11.0.66 on a Windows 32 bit system (Windows XP). We are running a Quickwin application. Recently we have installed Intel Visual Fortran Compiler 11.1.51 (ia32) on one of our computers. Also we have installed the application on a new computer with a Windows 64 bit system (Windows 7) with Intel Visual Fortran Compiler 11.1.51 (intel64).
In both cases the software runs without problems, apart from problems with setting properties in windows of the type windowconfig. In both cases, attributes such as "numxpixels" and "numtextcols" can be changed, whereas setting "title" to a new value does not have any effect. Trying to set the "fontsize" attribute on the 32-bit system even leads to a runtime-error: (forrtl: severe(157): Program Exception - access violation ... Stack Trace terminated abnormally. This was never a problem with earlier compiler versions.
Does anybody know what is causing this? I have attached some example code.
use ifqwin
implicit none
type(windowconfig) wind
status = getwindowconfig(wind)
wind%numxpixels = iwxgs
wind%numypixels = iwygs
wind%numtextcols = ncols
wind%numtextrows = nrows
wind%numcolors = -1
wind%fontsize = Z'0008000C'
wind%title = "This is a title"C
wind%bitsperpixel = -1
status = setwindowconfig(wind)
if (status.eq.0) status = setwindowconfig(feapgraph)
numfonts=initializefonts()
status = setfont( 't''Arial''h16b' )
Thanks...
Would you please attach a complete, buildable example that shows the problem? Too often an excerpt is missing critical code.
schuerg
Ok, i have created a little project that displays the behaviour i do not understand. I will paste the source code. If I run the program as shown, I get the above mentioned run time error. If I comment out the two lines in the code "window1%fontsize = #0008000E" and "window2%fontsize = #0008000E" OR the do-loop the program runs ok, but the titles of the two windows are not shown.
PROGRAM HELLO
integer i,j
do i=1,3
j = i+1
end do
call routine1
call routine2
END PROGRAM
subroutine routine1
use ifqwin
implicit none
type(qwinfo) winfo
type(windowconfig) window1
integer*4 status
integer*2 nxspix,nyspix,nrows,ncols
integer*2 nx1pix,ny1pix
integer(2) numfonts
real xfac1,yfac1
c open (unit=0,FILE='CON')
status = getwindowconfig(window1)
nxspix = window1%numxpixels
nyspix = window1%numypixels
ncols = window1%numtextcols
nrows = window1%numtextrows
xfac1 = 45./100.
yfac1 = 95./100.
nx1pix = nxspix*xfac1
ny1pix = nyspix*yfac1
nrows = 1000
ncols = 300
window1%numxpixels = nx1pix
window1%numypixels = ny1pix
window1%numtextcols = ncols
window1%numtextrows = nrows
window1%numcolors = -1
c window1%fontsize = Z'0008000C'
window1%title = "window 1"C
window1%bitsperpixel = -1
window1%mode = QWIN$SCROLLDOWN
status = setwindowconfig(window1)
if (status.eq.0) status = setwindowconfig(window1)
status = displaycursor($gcursoron)
status = SETBKCOLOR(15)
status = SETTEXTCOLOR(0)
CALL CLEARSCREEN ($GCLEARSCREEN)
status = getwsizeqq(0, QWIN$SIZECURR, winfo)
winfo%type = QWIN$SET
winfo%x = 0
winfo%y = 0
winfo%w = nx1pix
winfo%h = ny1pix
status = setwsizeqq(0,winfo)
status = FOCUSQQ(0)
end
subroutine routine2
use ifqwin
implicit none
integer*2 iwxs,iwys,iwxgs,iwygs
type(qwinfo) winfo
type(windowconfig) window2
integer isw
integer status
integer*2 nrows,ncols
integer(2) numfonts
c Open Child Graphic Window
open (unit=2,file='USER')
status = getwindowconfig(window2)
iwxs = window2%numxpixels
iwys = window2%numypixels
ncols = window2%numtextcols
nrows = window2%numtextrows
iwxgs = iwxs*0.8
iwygs = iwys*0.8
window2%numxpixels = iwxgs
window2%numypixels = iwygs
window2%numtextcols = ncols
window2%numtextrows = nrows
window2%numcolors = -1
c window2%fontsize = Z'0008000C'
window2%title = "window 2"C
window2.bitsperpixel = -1
status = setwindowconfig(window2)
if (status.eq.0) status = setwindowconfig(window2)
status = SETBKCOLOR(0)
winfo%x = 0
winfo%y = 0
winfo%w = iwxgs
winfo%h = iwygs
status = setwsizeqq(1,winfo)
status = CLICKMENUQQ(QWIN$TILE)
return
end
Thanks - I can reproduce this. Very, very strange. Why commenting out the DO loop has any effect, I don't know. It is clear that there is data corruption going on, but where and why... ? I will escalate this to the developers and see what they say.
Robert_M_Intel4
My name is Bob Mance and I've been working on this problem with Microsoft. I've posted a solution that works for yours, and several other reproducers posted in a separate (longer) thread. You can pick up a new ifqwin.lib file from that post, #94 I believe. The library was built for a 12.0/12.1 release and can be used on XP or Windows 7.
http://software.intel.com/en-us/forums/showthread.php?t=70026&p=10
Let me know if you try it and what you see. I have your application running here fine.
Bob
