29429 Discussions
how to catch the standard input file name?
yyxt11a
I want to read in data from a batch file by using the following command:
$ ./prog < input_001
Where prog uses the data from input_001.
If I have many input files as input_002, input_003 etc., how can I let the program know the name of the input file, so that it can do things accordingly?
mecej4
If what you want to do is to take as input the combined content of input_001, input_002, .., input_004 in that order, use:
[bash]cat input_001 input_002 input_003 input_004 | ./prog
[/bash]
If you need to use as input many more files, and you are sure that they are all present and contain the correct data, you could use:
[bash]cat input_* | ./prog
[/bash]
yyxt11a
This is what I wann do in `prog`:
if (file is input_001) then
elseif (file is input_002) then
elseif (file is input_003) then
end if
Hirchert__Kurt_W
New Contributor II
To the best of my knowledge, there is no way to get a file name for STDIN, because in the general case STDIN may not have a file name (e.g., it might be a pipe).
On the other hand, if you are willing to change your program invocation from
to
$ ./prog input_001
you could use the intrinsic subroutine GET_COMMAND_ARGUMENT to retrieve the first command argument as a character value (in this case, 'input_001'), and then use that character string both in your tests and in an OPEN statement, so you can read the file named.
Other approaches might involve wrapping your program in a shell script. For example
#!/bin/bash
echo $1 | cat - $1 | ./prog
would make your program see the filename on a line before the actual file contents, or
#!/bin/bash
./prog $1 < $1
would leave the file on STDIN and also make the name a command argument acessible through GET_COMMAND_ARGUMENT.
-Kurt
Try INQUIRE (UNIT=5,NAME=charactervariable) and see what you get.
yyxt11a
Many thanks for all the above answers. I've tried steve's method, and INQUIRE spitted out the name of the input file as '/dev/pts/67', which is not the original 'input_001'. However, correct file names were obtained when I tried to iINQUIRE non STDIN files.
