29422 Discussions
standardU.dll.manifest : general error c1010070: Failed to load and parse the manifest.
javids2002
I want to link Abaqus 6.11-2 to Visual Fortran to run a fortran subroutine in Abaqus. I have Microsoft Visual Studio 2010 (trial version) and Intel Composer XE 2011 (trial version) on my computer. When I run my job in Abaqus, the following error occurs:
Abaqus JOB umatmst3
Abaqus 6.11-2
Begin Compiling Abaqus/Standard User Subroutines
08/04/12 22:14:39
ifort: command line remark #10279: option '/QxW' is deprecated and will be removed in a future release. See '/help deprecated'
ifort: command line warning #10161: unrecognized source type 'Od'; object file assumed
ifort: command line warning #10161: unrecognized source type 'Zi'; object file assumed
ifort: warning #10146: no action performed for specified object file(s)
End Compiling Abaqus/Standard User Subroutines
08/04/12 22:14:39
Begin Linking Abaqus/Standard User Subroutines
08/04/12 22:14:39
Creating library standardU.lib and object standardU.exp
Microsoft Manifest Tool version 5.2.3790.2076
Copyright (c) Microsoft Corporation 2005.
All rights reserved.
standardU.dll.manifest : general error c1010070: Failed to load and parse the manifest. The system cannot find the file specified.
Abaqus Error: Problem during linking - Abaqus/Standard User Subroutines.
This error may be due to a mismatch in the Abaqus user subroutine arguments.
These arguments sometimes change from release to release, so user subroutines
used with a previous release of Abaqus may need to be adjusted.
Abaqus/Analysis exited with errors
I have spent more than 3 weeks searching internet to resolve the problem. It would be very appreciated if anyonecould help me resolve this problem.
Thanks a lot,
Samad
The following lines:
are the real key. They indicate that the command line given to compile your Fortran subroutines was incorrect. Instead of /Od and /Zi, the line probably had something like .Od and .Zi. You didn't show the script or batch file that is used to compile the Fortran code, but you need to correct it. Once you do that, the other errors will probably go away.
Really, this is an issue with how you are using Abaqus, and you might have fared better had you started with Abaqus support.
javids2002
Dear Steve,
Thank you very much for youranswer.
Before comming to this forum, I had called Abaqus Support Center and they said I should call Intel Support Center.
Where can I find the script or batch file that is used to compile the Fortran code? It should be a part of Abaqus, shouldn't it?
Samad
javids2002
Dear Steve,
Thank you very much for your help.
I found the file compiling and linking fortran subroutines. It is a .env file. As you said, instead of '/Od' and '/Oz' it contained 'Od' and 'Oz' . I changed them and the two warnings were removed,butthe errorstill exists.
The new error file is as follows:
Abaqus JOB umatmst3
Abaqus 6.11-2
08/05/12 23:45:36
08/05/12 23:45:36
08/05/12 23:45:36
The .env file (abaqus_v6.env) is as follows:
# System-Wide Abaqus Environment File
standard_parallel = ALL
mp_mode = MPI
mp_file_system = (DETECT,DETECT)
mp_environment_export = ('MPI_PROPAGATE_TSTP',
'ABA_CM_BUFFERING',
'ABA_CM_BUFFERING_LIMIT',
'ABA_ITERATIVE_SOLVER_VERBOSE',
'ABA_DMPSOLVER_BWDPARALLELOFF',
'ABA_ELP_SURFACE_SPLIT',
'ABA_ELP_SUSPEND',
'ABA_HOME',
'ABA_MEMORY_MODE',
'ABA_MPI_MESSAGE_TRACKING',
'ABA_MPI_VERBOSE_LEVEL',
'ABA_PATH',
'ABA_RESOURCE_MONITOR',
'ABA_RESOURCE_USEMALLINFO',
'ABAQUS_LANG',
'ABAQUSLM_LICENSE_FILE',
'ABQ_CRTMALLOC',
'ABQ_DATACHECK',
'ABQ_RECOVER',
'ABQ_RESTART',
'ABQ_SPLITFILE',
'ABQ_XPL_WINDOWDUMP',
'ABQ_XPL_PARTITIONSIZE',
'ABQLMHANGLIMIT',
'ABQLMQUEUE',
'ABQLMUSER',
'CCI_RENDEZVOUS',
'DOMAIN',
'DOMAIN_CPUS',
'DOUBLE_PRECISION',
'FLEXLM_DIAGNOSTICS',
'FOR0006',
'FOR0064',
'LD_PRELOAD',
'MP_NUMBER_OF_THREADS',
'MPC_GANG',
'MPI_FLAGS',
'MPI_RDMA_NENVELOPE',
'MPI_SOCKBUFSIZE',
'MPI_WORKDIR',
'MPCCI_SERVER',
'MPCCI_INITIAL_EXCHANGE',
'_MPCCI_CCM_CODE_IDS',
'_MPCCI_CODE_IDSTRING',
'ABAQUS_CCI_DEBUG',
'NCPUS',
'OMP_DYNAMIC',
'OMP_NUM_THREADS',
'OUTDIR',
'PAIDUP',
'PARALLEL_METHOD',
'RAIDEV_NDREG_LAZYMEM',
'ABA_SYMBOLIC_GENERALCOLLAPSE',
'ABA_SYMBOLIC_GENERAL_MAXCLIQUERANK',
'ABA_ADM_MINIMUMINCREASE',
'ABA_ADM_MINIMUMDECREASE',
'IPATH_NO_CPUAFFINITY',
'MALLOC_MMAP_THRESHOLD_',)
import driverUtils, os
compile_cpp=['cl', '/c', '/nologo', '/W0', '/MD',
'/TP', '/EHsc', '/DNDEBUG', '/DWIN32', '/DTP_IP', '/D_CONSOLE',
'/DNTI', '/DFLT_LIC', '/DOL_DOC', '/D__LIB__', '/DHKS_NT',
'/DABQ_NTI_NET', '/DFAR=', '/D_WINDOWS', '/DABQ_WIN86_64',
'/O1', '/I%I']
compile_fortran=['ifort', '/c','/DABQ_WIN86_64',
'/recursive', '/Qauto-scalar', '/QxW', '/nologo', '/Od', '/include:%I', '/Od', '/Zi'] #<------Editted line
# '/recursive', '/Qauto-scalar', '/QxW', '/nologo', '/Od', '/include:%I', 'Od', 'Zi']#<------The original line
link_sl='cmd /c "LINK /DEBUG /nologo /INCREMENTAL:NO /subsystem:console /machine:AMD64 /NODEFAULTLIB:LIBC.LIB /NODEFAULTLIB:LIBCMT.LIB /DEFAULTLIB:OLDNAMES.LIB /DEFAULTLIB:LIBIFCOREMD.LIB /DEFAULTLIB:LIBIFPORTMD.LIB /DEFAULTLIB:LIBMMD.LIB /DEFAULTLIB:MSVCRT.LIB /DEFAULTLIB:kernel32.lib /DEFAULTLIB:user32.lib /DEFAULTLIB:advapi32.lib /FIXED:NO /dll /def:%E /out:%U %F %A %B oldnames.lib user32.lib ws2_32.lib netapi32.lib advapi32.lib && mt /manifest %U.manifest /outputresource:%U;2 && del %U.manifest"'
link_exe='cmd /c "LINK /DEBUG /nologo /INCREMENTAL:NO /subsystem:console /machine:AMD64 /STACK:20000000 /NODEFAULTLIB:LIBC.LIB /NODEFAULTLIB:LIBCMT.LIB /DEFAULTLIB:OLDNAMES.LIB /DEFAULTLIB:LIBIFCOREMD.LIB /DEFAULTLIB:LIBIFPORTMD.LIB /DEFAULTLIB:LIBMMD.LIB /DEFAULTLIB:MSVCRT.LIB /DEFAULTLIB:kernel32.lib /DEFAULTLIB:user32.lib /DEFAULTLIB:advapi32.lib /FIXED:NO /LARGEADDRESSAWARE /out:%J %F %M %L %B %O oldnames.lib user32.lib ws2_32.lib netapi32.lib advapi32.lib && mt /manifest %J.manifest /outputresource:%J;1 && del %J.manifest"'
# Link command to be used for MAKE w/o fortran compiler.
# remove the pound sign in order to remove the comment and have the file take effect.
#link_exe='cmd /c "win64CmpWrp -m64 -intel10x LINK /nologo /INCREMENTAL:NO /subsystem:console /machine:AMD64 /NODEFAULTLIB:LIBC.LIB /NODEFAULTLIB:LIBCMT.LIB /DEFAULTLIB:OLDNAMES.LIB /DEFAULTLIB:MSVCRT.LIB /DEFAULTLIB:kernel32.lib /DEFAULTLIB:user32.lib /DEFAULTLIB:advapi32.lib /FIXED:NO /LARGEADDRESSAWARE /out:%J %F %M %L %B %O oldnames.lib user32.lib ws2_32.lib netapi32.lib advapi32.lib && win64CmpWrp -m64 -intel10x mt /manifest %J.manifest /outputresource:%J;1 && del %J.manifest"'
# MPI Configuration
mp_mode = THREADS
mp_mpi_implementation = NATIVE
mp_rsh_command = 'dummy %H -l %U -n %C'
mp_mpirun_path = {}
mpirun = ''
progDir = os.environ.get('ProgramFiles','C:\\Program Files')
for mpiDir in ('Microsoft HPC Pack', 'Microsoft HPC Pack 2008 R2', 'Microsoft HPC Pack 2008', 'Microsoft HPC Pack 2008 SDK'):
mpirun = progDir + os.sep + mpiDir + os.sep + 'bin' + os.sep + 'mpiexec.exe'
if os.path.exists(mpirun):
mp_mpirun_path[NATIVE] = mpirun
break
if os.environ.has_key('CCP_HOME'):
from queueCCS import QueueCCS
queues['default'] = QueueCCS(queueName='share')
queues['share'] = QueueCCS(queueName='share')
queues['local'] = QueueCCS(queueName='local')
queues['genxmlshare'] = QueueCCS(queueName='genxmlshare')
queues['genxmllocal'] = QueueCCS(queueName='genxmllocal')
del QueueCCS
mpirun = os.path.join(os.environ['CCP_HOME'], 'bin', 'mpiexec.exe')
run_mode=BATCH
if mp_mpirun_path:
mp_mode=MPI
del progDir, mpiDir, mpirun
graphicsEnv = driverUtils.locateFile(os.environ['ABA_PATH'],'site','graphicsConfig','env')
if graphicsEnv:
execfile(graphicsEnv)
else:
raise 'Cannot find the graphics configuration environment file (graphicsConfig.env)'
del driverUtils, os, graphicsEnv
abaquslm_license_file="27000@r0147209"
doc_root="http://R0206374:2080/v6.11"
doc_root_type="html"
academic=RESEARCH
I wouldappreciated it if you could pleasehelp me more.
Samad
There is some error running the Manifest Tool (mt.exe) from the set of commands in your environment file. I would guess that it is unable to find standardU.dll. The .env file you show is something specific to Abaqus and I am not completely sure how to interpret it, as it obviously does some symbol substitution. But let me suggest that you change:
to:
/outputresource:%J;#1
in the two places it appears.
javids2002
Dear Steve,
Than you for your comment.
I made your suggested change in the .env file, but it did not sole the problem.
Thanks a lot,
Samad
javids2002
Dear Steve,
Thanks a lot,
Samad
Given that you have had several transcription errors in the .env file already, I wonder if there are others. Your problem is not with Intel Fortran. If you can provide a log of the commands actually executed, perhaps we can help you, but otherwise we're just guessing. The basic issue seems to be that the mt command is being asked to do something to a file it can't find. Is your DLL actually in the location you think it is? What is the full path to the DLL?
Nasim_L_
Well, it has been a while since you have posted the problem and hopefully you have already solved it. Otherwise, you can try to add "/manifest /manifestfile:%U.manifest" to the first line of the link_sl in the .env file as follows: link_sl='cmd /c "LINK /manifest /manifestfile:%U.manifest /nologo /INCREMENTAL:NO /subsystem:console /machine:AMD64 /NODEFAULTLIB:LIBC.LIB /NODEFAULTLIB:LIBCMT.LIB /DEFAULTLIB:OLDNAMES.LIB /DEFAULTLIB:LIBIFCOREMD.LIB /DEFAULTLIB:LIBIFPORTMD.LIB /DEFAULTLIB:LIBMMD.LIB /DEFAULTLIB:MSVCRT.LIB /DEFAULTLIB:kernel32.lib /DEFAULTLIB:user32.lib /DEFAULTLIB:advapi32.lib /FIXED:NO /dll /def:%E /out:%U %F %A %B oldnames.lib user32.lib ws2_32.lib netapi32.lib advapi32.lib && mt /manifest %U.manifest /outputresource:%U;2 && del %U.manifest"' It solved the problem for me.
David_M_19
This post is quite old but I was wondering if anyone could help me.
I had the same errors when trying to link Abaqus 6.10 to Visual Studio 10.0 x64 and Intel Fortran 11.1 x64 (both compatible with this version of Abaqus) on Windows 7 x64:
using abaqus command prompt:
C:\SIMULIA\TEMP>abaqus job=Job-1-VUMAT user=VUMAT_file
Begin Compiling Single Precision Abaqus/Explicit User Subroutines
1/9/2014 4:36:10 PM
End
1/9/2014 4:36:11 PM
Begin Linking Single Precision Abaqus/Explicit User Subroutines
1/9/2014 4:36:11 PM
         Creating library explicitU.lib and object explicitU.exp
Microsoft (R) Manifest Tool version 5.2.3790.2076 Copyright (c) Microsoft Corporation 2005.
explicitU.dll.manifest : general error c1010070: Failed to load and parse the manifest. The system is unable to localize the specified file.
Problem during linking - Single Precision Abaqus/Explicit User Subroutines.   This error may be due to a mismatch in the Abaqus user subroutine arguments.   These arguments sometimes change from release to release, so user subroutines   used with a previous release of Abaqus may need to be adjusted.
I tryed to apply the suggestions from the folowing websites but they were written for 32-bit systems if I'm not wrong:
http://polymerfem.com/showthread.php?910-succeed-in-installing-ABAQUS-subroutine
What could I try to solve this problem?
Thank you in advance for your time and attention.
David Melo - Portugal
Without seeing the exact commands that the Abaqus script used, it's difficult to diagnose this. In general, this error means that the DLL was created in a different place than the manifest tool (mt.exe) was told to look for it.  I suggest you start with Abaqus support for help with this.
