29642 Discussions
write an allocatable array in a file
Mirzaee__Saeed
hi I have a 2 dimension allocatable array which I need to write each row of the array in one line of output file. the problem is that I don't know the size of array so I can't use formats like '(8(f8.2,x))'. please consider this program: program Console8 implicit none integer(8) :: i,n,m real,allocatable ::bt(:,:) open(unit = 1, file ='output.txt') read*,n,m allocate(bt(n,m)) do i=1,n bt(i,1:m) = i write(1,*) bt(i,1:m) end do end program Console8 for example : the file output.txt for n=2,m=8 will be 1.000000 1.000000 1.000000 1.000000 1.000000 1.000000 1.000000 1.000000 2.000000 2.000000 2.000000 2.000000 2.000000 2.000000 2.000000 2.000000 But I need it to be 1.000000 1.000000 1.000000 1.000000 1.000000 1.000000 1.000000 1.000000 2.000000 2.000000 2.000000 2.000000 2.000000 2.000000 2.000000 2.000000 any idea? Thank you.
FortranFan
Look into the unlimited format item option in the language standard e.g., fmt="(*(F8.2,1X))"
https://software.intel.com/en-us/fortran-compiler-19.0-developer-guide-and-reference-format-specifications
Greg_T_
Valued Contributor I
In addition to the unlimited format item, I've had success using this syntax with a value in the <> brackets before the format type specifier in this snippet example:
numColumn = 8
do row=1,numRow
  write(*,1)array(row,1:numColumn)
end do
1 format(<numColumn>(e16.8))
Regards, Greg
gib
New Contributor II
Another option is to use something like this:
write(1,'(100f8.2)') bt(i,1:m)
where 100 is guaranteed to be bigger than any m.  Note that the format can allow more than you use.
Gib
John_Campbell
New Contributor II
You could consider less restrictions on the format of output.txt. I would suggest you place more information in the file and make it "easier" to "view". Unless you have a very large matrix to transfer, the extra overhead of the approach below should not be a significant issue.
program Console8
 implicit none
 integer(8) :: i,n,m
 open(unit = 11, file ='output.txt')
 read*,n,m
 allocate(bt(n,m))
 write (11,*) n, "  rows of matrix"
 do i=1,n
  write (11,*) i,m
  bt(i,1:m) = i
  do j = 1,m
   write(11,*) bt(i,j)
  end do
 end do
FortranFan
Greg T. wrote:
In addition to the unlimited format item, I've had success using this syntax with a value in the <> brackets before the format type specifier ..
A caveat: this is an extension, not part of the Fortran standard.
WHARR5
John Campbell's solution is a good one if you wish to avoid formatting.
Here's a tweak of your program using formatting, and Greg T's comment:
program Console8
implicit none
integer(8) :: i,n,m,J !Try n=2; m=8
!open(unit = 1, file ='output.txt')
read*,n,m
allocate(bt(n,m))
do i=1,n
bt(i,1:m) = i
!write(*,*) bt(i,1:m)
write(*,'(<m>(f9.6))')(bt(i,J),J=1,m)
end do
I've added the index J to facilitate the format statement replacing your 'Write' statement (which I've commented out). Also - unlike your 'unit 1' output - I display the output on my output display screen, which accommodates a field width of only 80 characters. So 'm' greater than 8 would wrap around into the next line on that display. I don't know what format you have in mind for larger values of 'm'. Good Luck.
