Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
Instruction set latency
sebitab
Hello, I am working on assembly code optimization, I already read the code optimization manual, but I am interested in a list with the instruction set latencies. I search the intel site but I could not find it.
Where can I found this?.
Thanks for your answers.
Thomas_W_Intel
Quoting - sebitab
The latencies are listed in Appendix C of the "Intel 64 and IA-32 Architectures Optimization Reference Manual", which can be downloaded here.
Kind regards
Thomas
jancino
Quoting - sebitab
You can use instruction latencies only for very rough approximation of real number of cycles taken, because actual results depends on whetevera operands are loaded to cache, other instructions in pipeline (conditions) and so on....
craigj0
I find the instruction tables found here: http://www.agner.org/optimize/ to be very helpful. They are not perfect but they provide a pretty good estimate.
Tal_U_Intel
Quoting - craigj0
You can also try using Intel Architecture Code Analyzer available on:
http://software.intel.com/en-us/articles/intel-architecture-code-analyzer/
It can help you find the dependency chains in your code.
Tal
