IPP 8.1 H264 performance
Ivan_K_
Hi, I downloaded 30-days evaluation version of IPP 8 and compiled video-encoder: umc_video_enc_con. Encoding speed for h264 looks too slow, compare to mpeg2: mpeg2 - 200 fps, mpeg4 - 130 fps, vc1 - 40 fps, h264 - 30 fps QUESTION: Is it a limitation of demo-version, bug or feature? Below is output screen of console application: umc_video_enc_con.exe d:encoder.cfg -c h264 -t 2 -r 720 480 -b 1800000 -i ice_720x480.yv12 -o ipp.h264 Intel(R) IPP: ippCore 8.0.0 (r40040) May 22 2013 ippSP SSE4.1/4.2 (p8)+ 8.0.0 (r40040) May 22 2013 ippIP SSE4.1/4.2 (p8)+ 8.0.0 (r40040) May 22 2013 ippVC SSE4.1/4.2 (p8)+ 8.0.0 (r40040) May 22 2013 ippCV SSE4.1/4.2 (p8)+ 8.0.0 (r40040) May 22 2013 ippCC SSE4.1/4.2 (p8)+ 8.0.0 (r40040) May 22 2013 Input file name: ice_720x480.yv12 Output file name: ipp.h264 Input data: YUV420 (8,8,8) PROG. 720x480 (1:1) Output stream: H264 YUV420 (8,8,8) PROG. 720x480 (1:1) 30.00fps 1800000bps P100 L30 Progress: 100.00%; Frames: 2013; FPS: 34.13 Statistic (2013 frames): Overall: 68.53 sec; 29.37 fps Encoding: 67.65 sec; 29.76 fps Conversion: 0.17 sec; 11821.75 fps Encoded size: 15207050 bytes Compression ratio: 68.62 Encoded/expected: 1.01
Gennady_F_Intel
Hello,  This is an expected behavior for h264 encoder. There are no limitation for evaluation version compare with commercial one. Please pay attention to this article describing legacy policy for this example follow the link: http://software.intel.com/en-us/forums/topic/401253
thanks
Sergey_K_Intel
Hi Ivan,
Another point is, that H.264 codec in UIC is parallelized with OpenMP. Could you try to build it multi-threaded? For that you need to enable OpenMP in h64_enc project.
Ivan_K_
Yes, I recompiled whole sources with "USE_OPENMP" (this need to add libiompstubs5md.lib) Encoding speed is the same 8-( I tried with different command-line options: -t,  --ipp_cpu, --ipp_threads Looks like the only one CPU core is running: UPU usage is 50-60% always Thanks
Roman_T_
Hi, Ivan!
You are not the first developer who has problem with H264 encoding via UIC.
As it was said previously UIC - deprecated.
But I noticed inside this forum at least one success implementation of H264 encoding via Intel Media SDK.
Media SDK is free of charge now and it has full support of intel.
Roman
Bernard
Valued Contributor I
>>>Looks like the only one CPU core is running: UPU usage is 50-60% always>>>
Can you check with Process Explorer how many threads were created?
