6845 Discussions
Is there any float type IMAGE SAMPLING function ?
yevgbeid
Hi !
I've found only 8u type sampling function under JPEG function in IPP ?
Is there any float typeIMAGE SAMPLING function ?
Jack
Vladimir_Dudnik
Hi Jack,
The functions you can see in ippJP library are JPEG/JPEG2000 specific. For general image processing functions you should take a look on ippIP library. I believe ippiResize function can fit your needs, it supports 8u, 16u and 32f data types.
Vladimir
yevgbeid
Hi again !
Thanks for your prompt reply . ippiResize is comparetevely slowagainst sampling function ( by factor 3 or 5 ) and uses averaging algorothm , I'd like to find sampling function for image processing like it exists for signal processing , but imageoriented .
Vladimir_Dudnik
we do not have such functions for images. But you can use existing 1D functions (from ippSP) on row by row basis. What do you think?
Vladimir
yevgbeid
Hi again !
Thanks for your reply . It could be useful , but now there is a question of performance and if is it any advantage agaist regular C code . Should be checked.
Jack
Vladimir_Dudnik
Right, I hope performance will be good enough. Please report ifyou findsome problems with that.
Vladimir
