您好,我在 crypto_mb 中使用了 internal/common/ifma_cvt52.h 加载数据(ifma_HexStr8_to_mb8),然后返回(ifma_mb8_to_HexStr8)。但结果没有恢复到原来的值?
Dear Liu666,
Can you translate your question into English? We encourage all Intel IPP Community users to post content in English, as the Intel IPP Community is an open discussion thread that allows all IPP users around the world to understand posts and help each other.
-Ruqiu
1. Hello, I used internal/common/ifma_cvt52.h in crypto_mb to load the data (ifma_HexStr8_to_mb8) and then return (ifma_mb8_to_HexStr8). But the result is not restored to the original value?
2. Or can you write a test case to call crypto_mb/ec_sm2.h ::
Dear Liu666,
Thank you for posting your question here.
Can you provide out more information for this issue?
1. Which IPP Crypto version are you using? as well as OS, CPU information, etc.?
2. It's always good to provide out a simple reproducer as well as introduction about how to reproduce the issue, then other community users might help you find out root cause quickly.
- Ruqiu
