ipp_*.h headers missing form installation
Intel_C_Intel
I use IPP 5.2.063 evaluation version for Windows.
How can I use library if there is not possible to compile ?
Is it possible to get ipp_*.h headers in evaluation version?
Vladimir_Dudnik
which exactly files do you mean?
Vladimir
Vladimir_Dudnik
If you read available IPP materials carefully you may see that these headers for static IPP libraries. In evaluation version of IPP we provide only DLLs, so these files are not available in evaluation version as well.
Vladimir
Vladimir_Dudnik
Using static version is not necessary gives you advantages in performance. Originally for static version we have the folloving reasons:
-use IPP in kernel mode drivers
-reduce run time dependancy on big set of DLLs
but of course there is some advantages from using DLLs (like easy and automatic update your application with new versions of IPP without need to recompile or relink your application). Note also, that IPP DLLsprovide internal threading even in evaluation version
Vladimir
