17263 Discussions
4bit adder using vhdl error 10500
hi every one
i have a problem in compiling 4bit adder using vhdl in quartus 2 10.1
cyclone 2 ep2c35f672c6
Library ieee;
Use ieee.std_logic_1164.all;
Entity 4bitadder is -- it is showing error here
Port
I0,I1 : in STD_LOGIC_VECTOR(3 downto 0);
Cin : in STD_LOGIC;
S : out STD_LOGIC_VECTOR(3 downto 0);
Cout : out STD_LOGIC
End 4bitadder;
Architecture arch of 4bitadder is --it is showing error
Component fulladder
Port
A,B,Cin : in std_logic;
S,Cout : out std_logic
End component;
Signal Temp : STD_LOGIC_VECTOR(2 downto 0);
begin
FA1: fulladder port map
A => I0(0),
B => I1(0),
Cin => Cin,
S => S(0),
Cout => Temp(0)
FA2: fulladder port map
A => I0(1),
B => I1(1),
Cin => Temp(0),
S => S(1),
Cout => Temp(1)
FA3: Fulladder port map
A => I0(2),
B => I1(2),
Cin => Temp(1),
S => S(2),
Cout => Temp(2)
FA4: fulladder port map
A => I0(3),
B => I1(3),
Cin => Temp(2),
S => S(3),
Cout => Cout
End arch;
wheather i have to include 1 bit adder in this or as an another file when using component instantiation please tell me that
my errors are
Error (10500): VHDL syntax error at 4bitadder.vhd(4) near text "4"; expecting an identifier
Error (10500): VHDL syntax error at 4bitadder.vhd(14) near text "4"; expecting an identifier
please help me as soon as possible.
The first character of a VHDL identifier must be a letter.
You can't define 4bitadder entity: you can use adder4bit instead
