Conduit roles
omerc
Hello Everyone,
I hope all you are doing great!
My question is: I have one component with a conduit which has 3 signals with  3 distinct roles:
component1:
conduit1   -  Conduit
Name Role Width Direction Description
c1_s1 enable 1 Output no description
c1_s2 valid 1 Output no description
c1_s3 data 32 Output no description
And I have another component with 2 conduits but matching roles to the other component's conduit roles' :
component2:
conduit1  -  Conduit
c2_s1 valid 1 Input no description
conduit2  -  Conduit
c2_s2 data 32 Input
no description
Now can I connect those two latter conduits to the first conduit and hope Qsys will automatically recognize and connect the lines based on roles?
sthg like this:
add_connection compnent1.conduit1 component2.conduit1
add_connection component1.conduit1 component2.conduit2
what I would like to have in the end is have the signals connected:
c1_s2 connected to  c2_s1
c1_s3 connected to c2_s2
(c1_s1 no connection.)
Can I do it in this way?
If not, what would be the way to achieve this connectivity in the end given such conduit and signal arrangement?
Ömer.
RichardTanSY_Intel
Hi @omerc
I don't see any problem for now.
Do make sure that to connect two conduit interfaces inside Platform Designer( formerly called qsys), the following conditions must be met:
• The interfaces must match exactly with the same signal roles and widths.
• The interfaces must be the opposite directions.
• Clocked conduit connections must have matching associatedClocks on each of their endpoint interfaces.
Reference:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qps-platform-designer.pdf#page=180
Richard Tan
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos.
RichardTanSY_Intel
I have yet to receive any response from you to the previous question/reply/answer that I have provided but I believed that I have answered your question.
With that, I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Richard Tan
