HYPER_RETIMER Error
Please give some suggestion to solve this error
Error (332000): ERROR: Assignment HYPER_RETIMER has multiple values.
It looks like you're using the Hyper Retimer for working with a Stratix 10 device and there is something wrong with your assignment for enabling its use. Check your .qsf file.
Yes, Even I believe there is something wrong with HYPER_RETIMER.
I have used this assignment is qsf file
set_global_assignment -name HYPER_RETIMER ON
set_global_assignment -name HYPER_RETIMER_FAST_FORWARD ON
I even tried
set_global_assignment -name HYPER_RETIMER OFF
set_global_assignment -name HYPER_RETIMER_FAST_FORWARD OFF
But both didn't work
If you're using 16.1, the second assignment should be FLOW_ENABLE_HYPER_RETIMER_FAST_FORWARD or just enable it in the GUI. I don't know which version this was changed.
Yes correct, It has to be FLOW_ENABLE_HYPER_RETIMER_FAST_FORWARD.
I tried to enable and disable HYPER_RETIMER using GUI, but till it gives same error.
The error is inside a .sdc of DDR3 controller in qsys block.
Error (332000): ERROR: Assignment HYPER_RETIMER has multiple values. Use the "get_all_global_assignments" command to get all values or use the "get_global_assignment -front" command to get the first value.
while executing
"get_global_assignment -name "HYPER_RETIMER""
(procedure "altera_emif_arch_nf_160_pktenta_get_ddr..." line 9)
invoked from within
"altera_emif_arch_nf_160_pktenta_get_ddr_pins $instname allpins var"
(procedure "altera_emif_arch_nf_160_pktenta_initial..." line 15)
invoked from within
"altera_emif_arch_nf_160_pktenta_initialize_ddr_db altera_emif_arch_nf_160_pktenta_ddr_db var"
invoked from within
"if { ! [ info exists altera_emif_arch_nf_160_pktenta_sdc_cache ] } {
altera_emif_arch_nf_160_pktenta_init..."
(file "../altera_emif_arch_nf_160/synth/altera_emif_arch_nf_160_pktenta.sdc" line 122)
And, I'm using Arria 10 FPGA
Standard or pro edition? Pro 16.0 doesn't include the Hyper Retimer.
You also need additional licensing, I believe.
I'm using 16.0 Standard edition.
I don't think it's licensing issue because when I gave a try with standalone DDR project there was no error.
But with some other block integrated, this error comes up.
Hello Ak_M,
You have probably found a solution... But I ran into the same issue (also DDR3/Arria10). Commenting part of the generated script instance_name\altera_emif_arch_nf_160\synth\instance_name_altera_emif_arch_nf_160_wyghoeq_pin_map.tcl as follows solved the problem:
# with the hyper-retimer, the tdb netlist may contain the full set of routing nodes, so we need
# to search deeper
# if {[expr [get_global_assignment -name "HYPER_RETIMER"] == "ON"]} {
# set var(pll_inclock_search_depth) 250
# set var(pll_outclock_search_depth) 250
# set var(pll_vcoclock_search_depth) 50
# } else {
set var(pll_inclock_search_depth) 30
set var(pll_outclock_search_depth) 20
Of course, this is not ideal as this is a file which gets regenerated. However, from Q16.1 this seems to be fixed.
