Hi, I wanted to install -w_sys_dbg_nda_p_2022.2238.0_8346_offline for Intel CPU debug in Windows laptop. Couldn't complete installation with admin access enabled. Its giving power shell failures and reverting the installation. below is the error message
During the execution of the application 'C:\WINDOWS\system32\WindowsPowerShell\v1.0\powershell.exe' with arguments '-NoLogo -NoProfile -NonInteractive -ExecutionPolicy AllSigned -File C:\IntelSWTools/system_debugger/2238-nda/scripts/remove_pythonlauncher.ps1' errors were received:'
Error: Sequence execution failed
Attaching the error logs, kindly help to debug and complete the installation.
I've installed the package U2406 and the installation is successfull !
Hi Navya, we have sent you a private message. Please check your community inbox.
Hi Shivani and Delphine--G,
I got similar issue here, could you please help me ?
@RichieShen This thread is closed, if you are using System bring up toolkit NDA or System Debugger NDA, then you have priority support, I would advise you to open Priority support ticket so they can triage your issue and provide you resolution as its a NDA based toolkit and we cannot support it publicly in the forum, here is how to open support ticket https://www.intel.com/content/www/us/en/developer/articles/troubleshooting/how-to-create-a-support-request-at-online-service-center.html
