I am using Visual Studio Professional 2022 in an environment which the Internet access is unavailable.
To develop a software using oneAPI Base ToolKit, I got the offline installer from the folloing webcite and tried to install it, but an error occurs in Finalizing phase. The log is not displayed even after clicking the Show Log button.
https://www.intel.com/content/www/us/en/developer/tools/oneapi/base-toolkit-download.html?operatingsystem=window&distributions=offline
It seems that oneAPI is installed, but the Visual Studio extensions are not installed, therefore I cannot find "Intel Libraries for oneAPI" in the project properties on the Visual Studio.
For comparison, I installed Visual Studio Professional 2022 in an environment which the Internet access is available, and tried to install the oneAPI using offline installer.
The installation was done successfully. During the installation, I also checked the behavior during the Finalizing phase using Task Manager.
I confirmed that VSIXInstaller.exe was launched from the installer, and the VSIXIntaller.exe was accessing the Internet.
Comparing the results of the two installations, the following extensions were not installed in the former.
- Intel Advisor 2024
- Intel C++ Compiler
- Intel Libraries for one oneAPI
- Intel oneAPI DPC++ Compiler
- Intel oneAPI Menu & Samples
In Visual Studio Marketplace, only the extension for Intel C++ Compiler was found.
Other extensions could not be also found in an Internet search.
Where can I get offline installers for these extensions? Or is there a way to install them from the oneAPI offline installer?
We would appreciate it if you could help me.
Hi, Do you have priority support? If so I would recommend opening a ticket at
Online Service Center: https://supporttickets.intel.com/?lang=en-US
so we can better serve your request about a modified oneAPI installer or provide an appropriate workaround.
