using CLAPACK in mkl
itabhiyanta
Hi
I recently installed shifted my code to the intel compiler.
I have been using the clapack routines as provided in the ATLAS BLAS library and i am also using clapack for BLAS operations like ddot, daxpy, dnrm2 etc.
My code does not seem to compile correctly. i get undefined references fro all my clapack calls
clapack_dpotrs, clapack_dpotrf, clapack_daxpy clapack_ddot clapack_dnrm2. all of them are flagged as undefined references
I am including mkl.h and mkl_lapack.h (i couldn't find mkl_lapacke.h as suggested in the documentation)
the library component of my linkline looks like the following. whereINLIB2 is the path
opt/intel/Compiler/11.1/073/mkl/lib/em64t/
-Wl,--start-group -L$(INLIB2)/mkl_c.lib -L$(INLIB)/libmkl_intel_ilp64.a -L$(INLIB2)/libmkl_sequential.a -L$(INLIB2)/libmkl_core.a -Wl,--end-group -lpthread
I was earlier using ATLAS. My code development environment is for linux 64 bit environment. I am running the code on a Xeon machine.
I would really appreciate if someone could guide me where am i going wrong. I must mention the reason i am using clapack is that i cam coding in C and i wish to stay with the row major convention of storing the matrices.
thanks for reading my query
rohit
mecej4
The C_Lapack interfaces were not delivered with the 11.1 compilers. You can use the Fortran 77 interfaces, or download the C_Lapack source form Netlib and build the interface library.
A better alternative is the LapackE interface, which you can download and build likewise; one advantage of LapackE over C_Lapack is that the former is now integrated into MKL in version 12.0 of the compiler (10.3 is the MKL version).
itabhiyanta
Hi mecej4
thanks for your quick reply. so if i download the new version of the compiler (under the non-commercial section of intel's site) and the MKL and build both of them and then use the same link line as i had pasted in my original question it should ideally work right?
the other solution you suggest would mean one more library (which i compile against icc) which results from the compilation of the clapack source at netlib right?
thanks
rohit
itabhiyanta
Hi
actually my cblas interface is also not working
host_deflakernel.c_o: In function `calculate_Ptx':
host_deflakernel.c:(.text+0x11a2): undefined reference to `clapack_dpotrs'
wrapper.c_o: In function `hostcall':
wrapper.c:(.text+0x5bf): undefined reference to `cblas_dnrm2'
wrapper.c:(.text+0x627): undefined reference to `cblas_dnrm2'
slave_DPCG.c_o: In function `slaveDPCG':
slave_DPCG.c:(.text+0x7a8): undefined reference to `cblas_dcopy'
slave_DPCG.c:(.text+0x7d0): undefined reference to `cblas_daxpy'
slave_DPCG.c:(.text+0x7f0): undefined reference to `cblas_dcopy'
slave_DPCG.c:(.text+0x815): undefined reference to `cblas_dcopy'
slave_DPCG.c:(.text+0x9e1): undefined reference to `cblas_daxpy'
slave_DPCG.c:(.text+0xe4a): undefined reference to `cblas_dcopy'
host_cgkernel.c_o: In function `seq_cgsolver':
host_cgkernel.c:(.text+0xaf8): undefined reference to `cblas_dcopy'
host_cgkernel.c:(.text+0xb1e): undefined reference to `cblas_daxpy'
host_cgkernel.c:(.text+0xb3c): undefined reference to `cblas_dcopy'
host_cgkernel.c:(.text+0xb5a): undefined reference to `cblas_dcopy'
host_cgkernel.c:(.text+0xc70): undefined reference to `CLAPACK_dpotrf'
host_cgkernel.c:(.text+0xca1): undefined reference to `CLAPACK_dpotrs'
host_cgkernel.c:(.text+0xdcd): undefined reference to `cblas_daxpy'
host_cgkernel.c:(.text+0x10d3): undefined reference to `cblas_dnrm2'
host_cgkernel.c:(.text+0x19eb): undefined reference to `clapack_dpotrs'
host_cgkernel.c_o: In function `solverhost':
host_cgkernel.c:(.text+0x3888): undefined reference to `cblas_dcopy'
host_cgkernel.c:(.text+0x38ae): undefined reference to `cblas_daxpy'
host_cgkernel.c:(.text+0x38cc): undefined reference to `cblas_dcopy'
host_cgkernel.c:(.text+0x38ea): undefined reference to `cblas_dcopy'
host_cgkernel.c:(.text+0x3a00): undefined reference to `CLAPACK_dpotrf'
host_cgkernel.c:(.text+0x3a31): undefined reference to `CLAPACK_dpotrs'
host_cgkernel.c:(.text+0x3b5d): undefined reference to `cblas_daxpy'
host_cgkernel.c:(.text+0x3e63): undefined reference to `cblas_dnrm2'
host_cgkernel.c:(.text+0x477b): undefined reference to `clapack_dpotrs'
i ma using compiler version 11.1 and mkl version is 10.3 on a linux system (64 bit).
i am using the following link line library setting
-L/opt/intel/Compiler/11.1/073/mkl/lib/em64t//libmkl_blas95_ilp64.a -L/opt/intel/Compiler/11.1/073/mkl/lib/em64t//libmkl_lapack95_ilp64.a -L/libmkl_intel_ilp64.a -L/opt/intel/Compiler/11.1/073/mkl/lib/em64t/libmkl_sequential.a -L/opt/intel/Compiler/11.1/073/mkl/lib/em64t//libmkl_core.a -lpthread -lm
please suggest/advise.
rohit
TimP
Since you are confused about the meaning of -L library path designations for linking, please compare with the recommendations of the link advisor posted at the top of this forum. You don't need -lpthread to support mkl_sequential. Remember that your use of ilp64 libraries corresponds with long int function parameters and corresponding headers (the headers with int data types won't be compatible).
TimP
Basically, you've inserted -L directives where they aren't wanted. Where it's used, -L has to point to a directory, to be used in combination with -lsomelib, which (in the case of MKL) would expand to libsomelib.so, so it could be used for dynamic linking.
mecej4
You undertook some steps between #2 and #3 without taking us into your confidence. I can guess what happened, however:
1. You did not use the Link Advisor properly, as TimP already pointed out. You must read the documentation and understand the -L and -l options of compilers (which pass these options to the linker, ld ).
2. You are including irrelevant libraries such as libmkl_lapack95...
3. If you built, say, libclapack.a, you needed to add the option -lclapack to the recommended link line from the MKL Link Advisor, since the Advisor does not know about the need for third party libraries.
itabhiyanta
hi mecej4
indeed i didn't understand it correctly. i corrected that however i still have a issue. let me start by telling what are the steps i took.
SO i downloaded clapack
passed to it the path of the BLAS library from intel and compiled using icc.
/opt/intel/Compiler/11.1/073/mkl/lib/em64t/libmkl_blas95_ilp64.a
that generated a lapack_LINUX.a
i added this to the corrected link line from the link advisor as follows
-L/opt/intel/Compiler/11.1/073/mkl/lib/intel64 -Wl,--start-group -lmkl_intel_ilp64 -lmkl_sequential -lmkl_core -Wl,--end-group ../CLAPACK-3.2.1/lapack_LINUX.a -lm -L.
however when i run the code which calls dpotrf i get the following error
mpi_CPU_all:28458 terminated with signal 11 at PC=2aaabab89516 SP=7fff7240e2d0. Backtrace:
/opt/intel/Compiler/11.1/073/mkl/lib/em64t/libmkl_mc.so(mkl_lapack_ps_dpotrf_u_small+0x246)[0x2aaabab89516]
my call looks like this
dpotrf_( &upper, &numdomains, E, &numdomains, &info);
upper is a charatcer = 'U', info is an integer, numdomains is an integer and E is a array of doubles.
am i still doing something wrong in compilation? if not then why is the mkl_lapack_ps_dpotrf failing?
rohit
mecej4
use> /opt/intel/Compiler/11.1/073/mkl/lib/em64t/libmkl_blas95_ilp64.a
This library is relevant only if you are using Fortran 9+. For C/C++programs calling MKL, it is completely useless.
> dpotrf_( &upper, &numdomains, E, &numdomains, &info); ... and E is a array of doubles
You built C-lapack, and specified it in the link line, but your code still calls only the Fortran 77 routines. You must try harder to understand what you are doing.
E is supposed to be a 2-D array, in column-major order. You have not shown how E was declared, allocated and initialized.
You must read the MKL documentation and understand how to pass matrix arguments from C to Fortran. Failure to do so will cause all sorts of mysterious run-time errors such as seg-faults, array overruns, using uninitialized data, etc.
Alternatively, you could use the C-lapack or Lapack-E interfaces. Doing either will still involve reading the corresponding documentation and issuing correct calls.
itabhiyanta
Hi mecej4
I have tried to read through the documentation. For my version of the compiler 11.1 and nkl 10.3. when i look at the Intel MKL function for the dpotrs and dpotrf function they mention to include
mkl_lapacke.h file. I do not have that in my installation (rather the servers' installation).So i had downloaded CLAPACK since earlier i was working with ATLAS and then the integration of clapack_dpotrs and clapack_dpotrf was without any such problems or hassle.
I understand that i might have initially given you the impression that i do not even know how to link against libraries. That was due to the way i wrote here on the forum and i can apologize for that again.
I need your help to fix this issue so i state it again.
ON A BROAD LEVEL
I am trying to use CLAPACK becuase i have C code. I want to now use Intel C compiler with Intel MKL and want to stay with the row-major format of calling routines.
ON THE FUNCTION LEVEL
I use cblas_dcopy, cblas_ddot etc. also from the clapack interface
The matrix E that i pass to dpotrf is a symetric square matrix stored in row major order. I first call dpotrf and then call dpotrs to get a result.
Later on i use the result that dpotrf produces in matrix E to call dpotrs repeatedly.
I want to know
what files to include other than mkl.h to get the definition of this clapack routines which accept C interface. My understanding from the README at the netlib clapack project says it is dpotrf_ with arguments passed by reference (http://www.netlib.org/clapack/readme)
What i did.
I used the following link line (i am using MPI also so there are four slaves and 1 master for example and dpotrf and rs are called by the master)
LIB :=-L$(MKLROOT)/lib/intel64 -Wl,--start-group -lmkl_intel_lp64 -lmkl_intel_thread -lmkl_core -Wl,--end-group -openmp -lpthread -L$(CLAPCK_PATH)/my_clapack_library
You had suggested that i should provide the clapack libarary in this link line so i used that too. However like i had mentioned in the previous mail for a problem size of 1 million unknowns (i am writing out the code for conjugate gradient) i see this error about the segmentation fault.
I understand that the wrapper library just uses the BLAS routines from the Intel MKL and then one can use the routines from the CLAPACK implmentation and pass them arguments in C-style(row-major).
I request you to point out where all have i gone wrong.
thanks and regards
rohit
mecej4
Most of the advice given in this thread has gone unheeded, so let's try a different approach. Here is a small example of using the F77 interface to MKL from a C caller. There is no need to use CLapack or any library that is not already provided with Intel C 11.1 and MKL 10.2.
[cpp]#include
#include
#include
int main(int argc,char *argv[]){
double A[3*3]={  2.0, -1.0,  0.0,
                 0.0,  2.0, -1.0,
                 0.0,  0.0,  2.0},
         b[3]={1.0,2.0,3.0};
int n=3,info,nrhs=1; char uplo='L';
dpotrf_(&uplo,&n,A,&n,&info);
dpotrs_(&uplo,&n,&nrhs,A,&n,b,&n,&info);
printf("Solution: %10.4f %10.4f %10.4fn",b[0],b[1],b[2]);
[/cpp]
Since only the lower triangle of A is used, I have used zeroes to initialize the upper triangle.
Compile and run:
[bash]$ icc -mkl dpotrx.c
$ ./a.out
Solution:     2.5000     4.0000     3.5000
[/bash]
