I would like to use tbb::flow in the context of a Software Defined Radio (SDR)
application. This seems like a perfect fit, because I need to pipeline complex
algorithms.
I have read that TBB nodes use a push-pull process for communication---the
sender will push as long as the receiver is able to accept. If this is not
possible because the node is still running, the edge goes in a pull mode with
the receiver pulling results from the sender.
The problem I have is that some algorithms have multiple inputs which are
produced asynchronously. Thus, a join node is not feasible, because one input
might only be produced very rarely and I might not need it on every iteration.
I would like to have something similar to a multifunction node but with
multiple inputs which I pull in manually. An example use of such a
multi_io_node could be:
#include <cstdlib> // for rand() #include <chrono> // for sleep in ms #include <thread> // for sleep #include <tbb/flow_graph.h> using namespace ::tbb::flow; int main(int argc, char* argv[]) { graph g; // Create two source nodes auto source0 = source_node<int>{g, [] (int& out) { out = 0; return true; }, false}; auto source1 = source_node<int>{g, [] (int& out) { out = 1; return true; }, false}; // Create two sink nodes auto print_node0 = function_node<int, int>{g, 1, [] (int in) { std::cout << "print_node0 received input " << in << "\n"; return 0; }}; auto print_node1 = function_node<int, int>{g, 1, [] (int in) { std::cout << "print_node1 received input " << in << "\n"; return 0; }}; // TODO: This needs to be implemented auto selective_io = multi_io_node< tuple<int, int>, // input ports tuple<int, int>> { // output ports g, // graph 1, // concurrency (should probably be always 1) // lambda that reads and writes selectively [] (multi_io_node::input_port_type& ip, // input ports multi_io_node::output_port_type& op) { // output ports auto input_idx = static_cast<size_t>(rand() % 2); int value{0}; // read from one random input until its available // write to the corresponding output if (input_idx == 0) { while (!std::get<0>(ip).try_get(value)) { std::this_thread::sleep_for(std::chrono::milliseconds{1}); } std::get<0>(op).try_put(value); } if (input_idx == 1) { while (!std::get<1>(ip).try_get(value)) { std::this_thread::sleep_for(std::chrono::milliseconds{1}); } std::get<1>(op).try_put(value); } } }; // connect ports make_edge(source0, input_port<0>(selective_io)); make_edge(source1, input_port<1>(selective_io)); make_edge(output_port<0>(selective_io), print_node0); make_edge(output_port<1>(selective_io), print_node1); // start the (infinite) processing source0.activate(); source1.activate(); g.wait_for_all(); }
What do you think? Does this make sense? How would you implement this?
Hi Florian,
Thank you for the question. Unfortunally, I do not know the whole algorithm, however, according to your description I can suggest several options:
- You can use a separate function_node for each type of input. If you need to share the state you can pass the same reference/pointer to each function_node's body to have an access to the common data;
- Another option is to use indexer_node that adds tags for each input port and immediately forwards it to the successor;
You can combine this set of nodes to your own composite_node that will look like a multiinput and multioutput node.
Why do you need explicit pulling inside the node? It might lead to inefficiency and deadlocks.
If I missed something or you have questions, feel free to contact us in this thread.
Regards, Alex
Hi Florian,
Regards, Alex
Thank you very much, Alex.
Both of your ideas sound really nice and I will try them as soon as I find the time. I haven't thought about indexer_node, yet, and I am sure it could work out quite well.
The reason I wanted a node that always pulls is because thats how our current inefficient SDR framework works. Every processing step runs in a separate thread and pulls its input in from shared, lock-free queues. I hoped to plug in TBB as a more efficient replacement, at least until I could rewrite the algorithms to work with regular TBB nodes. However, all my current implementations suffer from deadlocks, indeed.
I will try to port our current algorithms to your implementation and do some profiling. I am certain that TBB could improve our performance massively.
