Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
3093 Discussions
Hardware AVC Encoding implementation configuration and usage
PhilippS1
I am currently trying to use the oneVPL sdk to encode frames rendered in DX11 on Windows on discrete intel GPUs.
I adjusted hello-encode sample to use hardware encoding as far as I understand, but when calling MFXVideoENCODE_Query(...) with the configured parameters (see attached code) it always tells me that it is unsupported (at line 71). I used the vpl-inspect.exe to give me information on the available implmentation and I think that I have the right one installed (see capabilities.txt)
So my questions are:
* Do I have to many parameters configured? Where is the configuration no supported? How can I check that?
* Do I need to install some additional software on my machine for it to be picked up?
Thanks in advance!
  loader_ = MFXLoad();
  VERIFY(NULL != loader_, "MFXLoad failed -- is implementation in path?");
  // Implementation used must be the type requested from command line
  cfg[0] = MFXCreateConfig(loader_);
  VERIFY(NULL != cfg[0], "MFXCreateConfig failed")
  sts = MFXSetConfigFilterProperty(cfg[0], (mfxU8*)"mfxImplDescription.Impl", cfgImplementationQueryFilter);
  VERIFY(MFX_ERR_NONE == sts, "MFXSetConfigFilterProperty failed for Impl");
  // Implementation must provide an AVC encoder
  cfg[1] = MFXCreateConfig(loader_);
  VERIFY(NULL != cfg[1], "MFXCreateConfig failed")
  cfgVal[1].Type = MFX_VARIANT_TYPE_U32;
  cfgVal[1].Data.U32 = TARGET_ENCODING;
  sts = MFXSetConfigFilterProperty(cfg[1], (mfxU8*)"mfxImplDescription.mfxEncoderDescription.encoder.CodecID", cfgVal[1]);
  VERIFY(MFX_ERR_NONE == sts, "MFXSetConfigFilterProperty failed for encoder CodecID");
  // Implementation used must provide API version 2.2 or newer
  cfg[2] = MFXCreateConfig(loader_);
  VERIFY(NULL != cfg[2], "MFXCreateConfig failed")
  cfgVal[2].Type = MFX_VARIANT_TYPE_U32;
  cfgVal[2].Data.U32 = VPLVERSION(MAJOR_API_VERSION_REQUIRED, MINOR_API_VERSION_REQUIRED);
  sts = MFXSetConfigFilterProperty(cfg[2], (mfxU8*)"mfxImplDescription.ApiVersion.Version", cfgVal[2]);
  VERIFY(MFX_ERR_NONE == sts, "MFXSetConfigFilterProperty failed for API version");
  sts = MFXCreateSession(loader_, 0, &session_);
  VERIFY(MFX_ERR_NONE == sts, "Cannot create session -- no implementations meet selection criteria");
  allocatorParams_.bUseSingleTexture = true;
  allocatorParams_.uncompressedResourceMiscFlags = 0;
  allocatorParams_.pDevice = d3d_device_.Get();
  allocator_.Init(&allocatorParams_);
  MFXVideoCORE_SetFrameAllocator(session_, &allocator_);
  VERIFY(MFX_ERR_NONE == sts, "Setting external frame allocator failed");
  MFXVideoCORE_SetHandle(session_, MFX_HANDLE_D3D11_DEVICE, d3d_device_.Get());
  VERIFY(MFX_ERR_NONE == sts, "Passing d3d11_device handle to onevpl failed");
  // Print info about implementation loaded
  ShowImplementationInfo(loader_, 0);
  // Initialize encode parameters
  encodeParams.IOPattern =  MFX_IOPATTERN_IN_VIDEO_MEMORY | MFX_IOPATTERN_OUT_VIDEO_MEMORY; //See https://spec.oneapi.io/versions/latest/elements/oneVPL/source/programming_guide/VPL_prg_hw.html
  // encodeParams.IOPattern = MFX_IOPATTERN_IN_SYSTEM_MEMORY;
  encodeParams.mfx.CodecId = TARGET_ENCODING;
  encodeParams.mfx.CodecProfile = MFX_PROFILE_AVC_CONSTRAINED_BASELINE;
  encodeParams.mfx.TargetUsage = MFX_TARGETUSAGE_BALANCED;
  encodeParams.mfx.TargetKbps = max_bitrate_;
  encodeParams.mfx.RateControlMethod = MFX_RATECONTROL_VBR;
  encodeParams.mfx.FrameInfo.FrameRateExtN = frame_rate_;
  encodeParams.mfx.FrameInfo.FrameRateExtD = 1;
  encodeParams.mfx.FrameInfo.FourCC = MFX_FOURCC_NV12;
  encodeParams.mfx.FrameInfo.ChromaFormat = MFX_CHROMAFORMAT_YUV420;
  encodeParams.mfx.FrameInfo.CropW = codec_settings->width;
  encodeParams.mfx.FrameInfo.CropH = codec_settings->height;
  encodeParams.mfx.FrameInfo.Width = ALIGN16(codec_settings->width);
  encodeParams.mfx.FrameInfo.Height = ALIGN16(codec_settings->height);
  mfxVideoParam outParams;
  sts = MFXVideoENCODE_Query(session_, &encodeParams, &outParams);
  VERIFY(MFX_ERR_NONE == sts, "Encode query failed");
  // Initialize encoder
  sts = MFXVideoENCODE_Init(session_, &outParams);
  VERIFY(MFX_ERR_NONE == sts, "Encode init failed");
  // Prepare output bitstream
  bitstream_.MaxLength = BITSTREAM_BUFFER_SIZE;
  bitstream_.Data = (mfxU8*)calloc(bitstream_.MaxLength, sizeof(mfxU8));
Rahila_T_Intel
After observation in your code, It seems like you are trying to encode video to AVC. (is it what you are doing)?
The code snippet you have given is not a complete one, hence it is very difficult for us to interpret what exactly you are wanting to do.
Can you provide the sample reproducer to understand better?
PhilippS1
thank you for answering!
I just saw that I said it fails on line 71, but it is actually 64 (this message should return MFX_NO_ERROR, but it returns MFX_NOT_SUPPORTED)
I only provided the sample for the initialization of the encoder because that is currently the only interesting part. In this part of the code it fails to find an appropriate encoder implementation on my system.
Also when trying to run the provided samples (legacy as well as the new ones) with
.\sample_encode.exe h264 -sw -i <input-file> -w 320 -h 240 -o test.h264
it fails with the following message (this is both for -sw & -hw)
Rahila_T_Intel
Please find the Encode Features for Intel® Discrete Graphics available from the below link.
https://www.intel.com/content/www/us/en/docs/onevpl/developer-reference-media-intel-hardware/1-1/features-and-formats.html#ENCODE-DISCRETE
Also find the oneVPL Dispatcher behavior when targeting Intel GPUs below:
https://github.com/oneapi-src/oneVPL#onevpl-dispatcher-behavior-when-targeting-intel-gpus
You can refer the below GitHub link to know the details about the Intel® oneVPL GPU and its supported hardware platforms, Supported video encoders, dependencies...etc.
https://github.com/oneapi-src/oneVPL-intel-gpu
Could you please provide us the answers to our below doubts so that we can debug your issue further?
1. Details about your application you attached.
2. Sample Reproducer i.e. the code which you've written and all the command to compile and analyze.
3. Are you able to run the original hello_encode sample which comes with oneVPL, in your system without any issues?
4. Can you share your the details of OS, Processor and oneVPL GPU Runtime version.
Rahila_T_Intel
We haven't heard back from you. Could you please give us an update?
Rahila_T_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
