I have an implemenation of your h264 SW and QSV encoders. For VBR rate control method, I expose the TargetKpps and the MaxKbps parameters but I am wondring if you have a "Minimum bitrate"?
The only thing I see concerning the minimum bitrate is the following you post here http://software.intel.com/en-us/forums/topic/404650
"Also, by default, Media SDK limits the compression ratio to 500x. So if you're trying to encode frames with resolution 1920x1080, then the default minimum bit rate is ~1500kbps, even if you set the rate to 500kbps. If you do not want to the SDK to impose this restriction, then please set the mfxExtCodingOption2.BitrateLimit parameter to "OFF"."
Karine
FYI my setup:
Intel Media SDK System Analyzer (64 bit)
The following versions of Media SDK API are supported by platform/driver:
Version Target Supported Dec Enc
1.0 HW Yes X X
1.0 SW Yes X X
1.1 HW Yes X X
1.1 SW Yes X X
1.3 HW Yes X X
1.3 SW Yes X X
1.4 HW Yes X X
1.4 SW Yes X X
1.5 HW Yes X X
1.5 SW Yes X X
1.6 HW Yes X X
1.6 SW Yes X X
1.7 HW Yes X X
1.7 SW Yes X X
1.8 HW No
1.8 SW Yes X X
Graphics Devices:
Name Version State
Intel(R) HD Graphics 4000 10.18.10.3412 Active
NVIDIA GeForce GT 545 9.18.13.1106 Active
System info:
CPU: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
OS: Microsoft Windows 8 Enterprise
Arch: 64-bit
The bitrate will be limited to 500x compression unless the BitrateLimit option is disabled, however this the stream may not conform with HRD. I believe the minimum is 1Kbps (1000 bps), but if that means significant compression you may be making a video that some decoders would have trouble with and has severe visual artifacts.
