Convert Encode RGB24 Uncompress Avi file to H.264
Omar_Barlas
I'm test Intel Media SDK now.
When I run sample program to encode RGB24 Un-compress avi video toencoded h264 OR MPEG2 file does not played inMedia Player. In VLC file play with show only Color Lines which move Horizontal and Vertical and Framerate also increase from 30 to 60
I convert the RBG24 to YUV420 Formt but result still same.
Encoded File screenshort is below
Thank in Advance
Nina_K_Intel
Hello Omar,
If you are using sample_encode please note that it requires pure raw video stream as input. AVI container contains meta information which being encoded as frame data results in such artifacted stream. As for output stream not playable with Windows Media Player this is again due to the sample specifics - it produces an elementary video stream. WMP is not able to playback elementary h.264 format.
If you would like to convert an AVI to MP4 for example you may use Media SDK Direct Show samples with GraphEdit application (FileSource Async->AVI Splitter->Color Converter -> Intel Media SDK H.264 Encoder -> Intel MSDK MP4 Muxer -> FileWriter)
Nina
gthomaz
And if you have some trouble connecting "Color Converter -> Intel Media SDK H.264 Encoder" (like Nina said), please make a search in this forum.... ;)
Good luck!
Omar_Barlas
Thanks for Help.
But After convert Avi video to Raw YUV format.Now I got Following Result
Source Video:
Encoded Video:
Tnanks in Advance
Nina_K_Intel
Hi Omar,
Sample_encode requires YUV 420 format and your source is YUY2 (YUV 422) as I see.
Nina
Omar_Barlas
Thanks for Reply
I Convert RGB to I420 format and then encode to MPEG2. Now Encoded Video Show good result but images are move horizontally as shown in below Image.
Sourc Image:
Nina_K_Intel
The result looks like you have provided wrong resolution to the sample_encode (width/2 instead of actual width). Could you share the command line you are using? Also please share the raw video after color conversion - you may cut several first frames and attach the stream here.
Nina
gthomaz
Are you using I420 like:
Y0Y1Y4Y5
Y2Y3Y6Y7.....
U...
V....
I don't know if I could explain.. but, are you shure that you are setting Y's correctly ?
Omar_Barlas
command
sample_encode mpeg2 -i 1.yuv -o result.mp4 -w 720 -h 576
and Source and Result File can be Download at following Link
http://www.sonovision2.com/downloads/VideoFile.zip
and one more question is that can i used Intel SDK H264 or Mpeg2 decoderin VB.net or Window Media Player as Decoder?
Omar_Barlas
Hi gthomaz
I don't kwn what is Y's setting. I convert RGB24 Source Avi file to Raw I420 format using following Command
mencoder.exe -of avi Source.avi -o 1.yuv -vf format=I420 -nosound -ovc raw
Nina_K_Intel
Hi Omar,
As far as the input YUV file for the sample_encode already looks bad this means you are doing something wrong at conversion stage. This is not an encoding problem.
In your command line for mencoder.exe please try removing '-of' option, it is mispaced and probably takes effect and results in avi container at output again.
Try this line
mencoder Source.avi -ovc raw -vf format=i420 -o out.yuv
If this doesn't help please share the Source.avi.
Nina
Nina_K_Intel
Regarding your other questions. As for VB.Net there was an answer posted in your older threadhttp://software.intel.com/en-us/forums/showthread.php?t=82102&o=a&s=lr
As for Windows Media Player it should be possible to use Media SDK decoders through Media Foundation and Direct Show sample decoder plugins. Likely you will need to experiment with GUIDs and merits to make WMP use those plugins, but it should work. Please give it a try.
Nina
Omar_Barlas
Hi Nina
I tried this line
but result still same. I upload Source and Result Files at following Link
http://www.sonovision2.com/downloads/SourceFile.zip
Nina_K_Intel
Hi Omar,
I checked mencoder at my side - the problem is that the default output container is AVI. To actually get the raw video stream you need to add the option -of rawvideo.
The whole line should be:mencoder Source.avi -of rawvideo -ovc raw -vf format=i420 -o out.yuv
I checked that it provides a raw video stream. The only problem I saw - some corruption on the first several frames. Seems that there's a problem in mencoder's color conversion algorithm.
To overcome this I used VirtualDubMode to change compression inside avi from cvid to IYUV and after that used mencoder to extract raw video from an avi. Having done all that I achieved a totally good looking YUV stream.
Please try. Also be sure to use the correct resolution with sample_encode after that - I noticed that Source.avi has the resolution 1024x768 and you encoded as 720x480.
Nina
Omar_Barlas
Hi Nina,
Thanks I also get good looking Video but Video movehorizontally and not playback as Video.
How can i solve this issue?
Nina_K_Intel
Hi Omar,
Based on the Source.avi you shared, the raw video after conversion and the encoded video after encoding with sample-encode playback totally fine at my side. Horizontal movement shows that you still get an avi file after conversion. Please check the command line arguments of mencoder.
Nina
Omar_Barlas
Hi Nina
Thanks for help. Issue is Fixed.
Nina_K_Intel
Very glad to hear that!
-Nina
Work_B_
I use iDealshare VideoGo to convert AVI to H.264, MPEG-4, MPEG-2,
Here is the step by step guide at http://www.idealshare.net/video-converter/avi-to-mp4-converter-mac-windows.html
Work_B_
Have you tried iDealshare VideoGo which can easily convert AVI to MPEG-2, H.264 or MPEG-4.
CNeva
The converter you recommend is a shareware, you have to pay for it to get the full version, or else there will be a big watermark in the converted video. To convert video, I'd recommend an online app called Acethinker Video Converter, It's a free web-based application to convert videos, you don't have to install anything. No watermark and limitation.
