I am running a NIOS II/f core with MPU enabled. However NIOS doesnt seem to like it when I enable the MPU in software. I have followed the Altera MPU application notes and examples in setting up my data and instruction regions. The memory map is attached. I am using Limit for the region sizes. The number of regions is 8 for both data and instructions and minimum size is 4K. My data and instruction region setup functions are below: void nios2_mpu_data_init() {Nios2MPURegion region[NIOS2_MPU_NUM_DATA_REGIONS]; unsigned int num_of_region = NIOS2_MPU_NUM_DATA_REGIONS; /* DDR RAM memory region */ region[0].index = 0; region[0].base = 0x10000; // Byte Address 0x10000000 region[0].mask = 0x20000; // Byte Address 0x20000000 region[0].c = 1; region[0].perm = MPU_DATA_PERM_SUPER_RW_USER_RW; /* System memory data region. */ region[1].index = 1; region[1].base = 0; // Byte Address 0 region[1].mask = 0x40; // Byte Address 0x40000. region[1].c = 1; region[1].perm = MPU_DATA_PERM_SUPER_RW_USER_RW; /* Debug RAM memory region */ region[2].index = 2; region[2].base = 0x10C; // Byte Address 0x10C000 region[2].mask = 0x10E; // Byte Address 0x10E000 region[2].c = 1; region[2].perm = MPU_DATA_PERM_SUPER_RW_USER_RW; /* Audio RAM memory region */ region[3].index = 3; region[3].base = 0x10E; // Byte Address 0x10E000 region[3].mask = 0x10F; // Byte Address 0x10F000 region[3].c = 1; region[3].perm = MPU_DATA_PERM_SUPER_RW_USER_RW; /* Host RAM memory region */ region[4].index = 4; region[4].base = 0x10F; // Byte Address 0x10F000 region[4].mask = 0x110; // Byte Address 0x110000 region[4].c = 1; region[4].perm = MPU_DATA_PERM_SUPER_RW_USER_RW; unsigned int index; unsigned int mask; /* Rest of the regions are maximally sized and restrictive to supervisor/user. */ mask = 0x80000; for (index = 5; index < num_of_region; index++){ region[index].base = 0x0; region[index].index = index; region[index].mask = mask; region[index].c = 1; region[index].perm = MPU_DATA_PERM_SUPER_NONE_USER_NONE; //No access for user and supervisor } nios2_mpu_load_region(region, num_of_region, 1); } void nios2_mpu_inst_init() {unsigned int mask; unsigned int num_of_region = NIOS2_MPU_NUM_INST_REGIONS; Nios2MPURegion region[NIOS2_MPU_NUM_INST_REGIONS]; //Main instruction region. region[0].index = 0; region[0].base = 0; // Byte Address 0 region[0].mask = 0x40; region[0].c = 0; region[0].perm = MPU_INST_PERM_SUPER_EXEC_USER_EXEC; /* Rest of the regions are maximally sized and restrictive to supervisor/user. */ mask = 0x80000; unsigned int index; for (index = 1; index < num_of_region; index++){ region[index].base = 0x0; region[index].index = index; region[index].mask = mask; region[index].c = 0; region[index].perm = MPU_INST_PERM_SUPER_NONE_USER_NONE; //No access for user and supervisor } nios2_mpu_load_region(region, NIOS2_MPU_NUM_INST_REGIONS, 0); } I have also added "flushp"s in the MPU load region function: void nios2_mpu_load_region(nios2mpuregion region[], unsigned int num_of_region, unsigned int d) {unsigned int region_num; Nios2MPURegion current_region; for(region_num = 0; region_num < num_of_region; region_num++){ current_region = region[region_num]; nios2_write_mpubase(current_region.base /*base*/, current_region.index /*index*/, d /*d*/); asm volatile("flushp"); nios2_write_mpuacc(current_region.mask /*mask*/, current_region.c /*c*/, current_region.perm /*perm*/, 0 /*rd*/, 1 /*wr*/); asm volatile("flushp"); } } What am I doing wrong here? Thanks in advance. RLink Copied
