12606 Discussions
Nios-II 1.1 EPCS Bootloader
Hi All,
After I boot from an epcs device the chip select remains asserted
(control register = 0x0000_0400).
Has anyone else observed this?
--Scott
BTW: This causes the u-boot epcs command to fail the first time
it is invoked.
Yes, see this topic - look for the post from Kero Kero for a workaround:
http://www.niosforum.com/forum/index.php?a...ct=st&f=2&t=850 (http://www.niosforum.com/forum/index.php?act=st&f=2&t=850)
Thanks Jesse ...
... in general, it's probably good practice from a software point-of-view to
assume that the chip select was left in an inappropriate initial state ...
... so it's time for me to use good practice ;-)
Thanks again,
--Scott
Just an FYI for anyone following this thread:
A jump to the reset address (soft reset) when booting from
the epcs_controller will cause the epcs boot loader to hang.
Prior to doing something like this, you must make sure the
epcs chip select is negated
--Scott
