Printing bdf in Q4.1
I am trying to print a bdf schematic large enough to read. It seems like it does not matter how the view is zoomed, when I print I always get the entire bdf sheet. I don't see that I have any option to resize the bdf sheet either.
Is this a printer driver issue or a Quartus issue?
I can capture sections of the screen to the clipboard, but the results are poor.
That's correct. The output simply resizes based on the region your logic takes up on the schematic. Is your schematic filled with logic or just blocks connecting together? (if it's just logic from personal experience I recommend subdividing your logic into blocks since big schematics are difficult for most to read).
The problem is the output does not resize, even if I scrunch everything together.
