12606 Discussions
Real-time Clock on Evaluation Board
Thanks in Advance.
I'm actually using a Macnica Helio Eval Board because it has the battery for the RTC
and my Altera Cyclone V Eval Board didn't come with a battery.
I can set the RTC with the "date -s" command but when I reboot it reverts back to the
time that was set using the "date -s" command. I want to have the RTC run when the
power is off.
I can see that I have a /dev/rtc entry but if I open the device can I configure the
RTC to keep running?
