**** Build of configuration Default for project mynios_ch395 ****
make all 系统找不到指定的路径。 系统找不到指定的路径。 Info: Building ../mynios_ch395_bsp/ make --no-print-directory -C ../mynios_ch395_bsp/ cygpath: can't convert empty path process_begin: CreateProcess(NULL, pwd, ...) failed. make[1]: *** No rule to make target `/system.h', needed by `all'. Stop. make: *** [../mynios_ch395_bsp/-recurs-make-lib] Error 2 **** Build Finished **** do i need to install MinGW and Msys? how to ?Link Copied
You only get the necessary definitions if you run your build in the Nios II command shell. This is in the windows start menu.
Topic Options
