12605 Discussions
read(10) with USB controller cy7c67200
Hello I use the cy7c67200 (EZ-OTG) on a fpga (Altera DE2-115). I successfully implemented The enumeration process and want to read now some data from a usb flash drive. But i have issues on that. Im not fully sure if I understand right how to do that, sadly i didnt found any examples which don't use high level frameworks and where i can see how i send CBWs (command block wrapper) and how i receive the CSW (Command Status Wrapper).
Thats why i like to describe how i do it in the hope someone can tell me if I do it right in general .
What i do is: i issue a bulk reset.
Then i write a setup TD (Transfer Descriptor) which points with its BaseAddr to the CBW content.
CBW (on position 0x50C):
Signature:
0x43425355
Tag:
0xfefefeed
DataTransferLength 0x200
Flags:
0x8
Lun:
0x0
Length:
0xa
CDB: 28 00 00 00 00 00 00 00 08 00
My wMaxPacketSize as reported by the endpoint descriptor is 64 so i think I have to define the length in the CDB as 8 if i want 512bytes?
TD (at position 0x500):
base_addr: 0x50c
port_length: 0x1c
pid_ep: 0x12
dev_addr: 0x2
ctrl_reg: 0x41
status: 0x0
retry_cnt: 0x1b
residue: 0x0
next_td_addr: 0x528
Then i write a (data) TD with PID_IN and point with the BaseAddr where i want the data should be written.
TD (at 0x528)
base_addr: 0x534
port_length: 0x200
pid_ep: 0x91
dev_addr: 0x2
ctrl_reg: 0x1
status: 0x0
retry_cnt: 0x1b
residue: 0x0
next_td_addr: 0x734
Then i write a (status) TD which points with BaseAddr where i want to read the CSW
TD(at
0x734)
base_addr: 0x740
port_length: 0x0
pid_ep:
0x11
dev_addr:
0x2
ctrl_reg:
0x1
status:
0x0
retry_cnt:
0x1b
residue:
0x0
next_td_addr: 0x0
Then i set the CurrentTDPointer to 500 and wait until the HPI_STATUS register reports TDListDone.
Then i read the data buffer at 0x534 where I expect the content from my usb device and i read the content
from 0x740 where i expect my CSW content.
But the data contains garbage, the csw signature for example is wrong and the csw tag is not equal to the value in my cbw.
Also the data which should be the 512 bytes of the flashdrive from LBA: 0 are not identical with the contents from the flashdrive.
