12606 Discussions
Configuration Tool Output Window
Hi!
I have started the eCos Configuration Tool and I am missing the output window. The other windows I can switch on and off with ALT+1/3/4. But for the Output window (ALT+2) nothing happens.
When building the demo for nano-tetris no executable is built and I can't imagine why. So I hope some iformation in the output window will help me!
Sepp
You can enable/disable windows from the "View" menu at the top of configtool. Hopefully that&#39;ll bring it back for you http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
ALT+2 didn&#39;t work.
The problem was found: In the Windows registry the coordinates for the OUTPUT window were set to 0/0. I have changed them to 200 / 220 and restarted the confoguration tool again. It seems OK now! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/rolleyes.gif
Sepp
