12699 Discussions
Custom component driver header file
Hi All,
I've created a custom hardware component that successfully integrates with Qsys and can be attached to a NIOS II/e core.
I'm now trying to persuade the Eclipse software build tools to include the component's header file within a BSP (The header just define basic IO macros). The component is very simple, so doesn't really need a full HAL driver, but for completeness, I'd like the header file (and perhaps a basic c library) automatically imported within the BSP.
Here is my _sw.tcl file:
# Create a new driver create_driver push_buttons_driver # Associate it with hardware set_sw_property hw_class_name PushButtons # The version of this driver set_sw_property version 1.0 # Location in generated BSP that sources will be copied into set_sw_property bsp_subdirectory drivers # Source file listings add_sw_property include_source inc/pushButtons_regs.h # This driver supports LWHAL (OS) types add_sw_property supported_bsp_type HAL add_sw_property supported_bsp_type UCOSII add_sw_property supported_bsp_type LWHAL
The directory structure is simple:
PushButtons - inc - pushButtons_regs.h - PushButtons.vhdl - PushButtons_hw.tcl - PushButtons_sw.tcl (as listed above)
If I create a new BSP the pushButton_regs.h file does not get copied into the Eclipse project.
So, two questions:
- Have I missed some obvious step/file in order to get this working?
- At what point is the PushButtons_sw.tcl file scanned to check for changes and hopefully copy component specific files into a BSP project? I'd hoped this would happen when 'Generate BSP' is selected from within Eclipse.
All component files are zipped up and attached below.
Many thanks
Andy
(Virus scan in progress ...)
