12692 Discussions
Multiple Eclipse installations - How to control which one?
Nikolay_Rognlien
Hi.
With Quartus 22.1 Standard on Windows, I had the recommended Eclipse CDT 8.8.1 installed as described in https://www.intel.com/content/www/us/en/docs/programmable/683525/21-3/windows-installation.html
It was working fine.
Then I also installed a standard Eclipse release from
https://www.eclipse.org/downloads/
Now both Quartus(Tools menu) and NiosII Command Shell launch the standard Eclipse (without NiosII support) instead of the CDT 8.8.1 version I placed under \22.1std\nios2sdk\bin\eclipse_nios2\
What mechanism controls which Eclipse version is launched? Can I control this?
Can multiple Eclipse versions coexist on a Windows machine?
/Nikolay
hareesh
now which one do you want to use?
don't install both. install any of one
Nikolay_Rognlien
Hi.
The question is not which one I want to use...
Eclipse does support to have multiple versions installed:
https://stackoverflow.com/questions/16764625/is-it-possible-to-have-multiple-eclipse-installs-on-one-computer
The question is why Nios II Software Build Tools for Eclipse starts without the NiosII plugins like "NiosII Application and BSP for Template" even after the generic Eclipse was uninstalled?
Best regards
Nikolay
hareesh
can you share screen shot of that where you are getting that?
and one question, because of that are facing any issues?
Nikolay_Rognlien
Problem was for some reason suddenly solved...
After uninstalling the "normal" Eclipse, the NiosII Eclipse still did not show the Templates.
However after digging down into File -> New -> Others the NiosII Templates could be found. After this, the Templates are now also visible under the File -> New section.
Something "hi-jacked" the view, and was restored by some coincident...
Can't explain it, but considering this case closed!
/Nikolay
hareesh
Thank you for update.
if you want re-open this case please follow bellow link.
Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
