I have two memory devices:
one is ram_on_chip another is sdram now i download code(*elf) into the above tow memory devices¡£ all is ok¡£ i'm sure that downloading is correct¡£(i check the address space using fs2 debugger ) now i debug the code¡£ when code in ram_on_chip¡£all is ok¡£ but when code go into sdram¡£all is blocking¡£ sosLink Copied
