UART with FIFO Buffer
Need to use UART with FIFO Buffer in SOPC Builder Nios II System:
1> The UART RS232 available in SOPC are without FIFO is it possible to add FIFO by modifying the same UART core
2> If not is there any other SOPC ready UART_FIFO core available as free IP
3> If not is it possible to get estimate of
- LE utilization without Modem Control logic
- Is it necessary to write device driver for the same
- Apprx how much design time it will take to
design HDL UART, device driver for a single person?
Please advice asap. running short of time.
Thanks in Advance
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/dry.gif what&#39;s wronged in this C file?
I&#39;m using FIFOed_avalon_uart Opencore
I can&#39;t transmit throught RS232 with this code using instruction
fifoed_avalon_uart_write(fp,byte/*Tx Pointer*/,25344);
(UART&#39;s light is always swithced off)
FILE* fp;
fp = fopen ("/dev/fifoed_avalon_uart_0", "w+"); // Read && Write
int ret;
if (fp!=NULL)
printf("\nOpen file");
ret = fflush(fp);
if(ret==0)
printf("\nFlushed file");
else
printf("\nNot flushed file");
//Polling
int j=0,k=0,z=0,controllo;
k=((ctrl/4)*(multi));
z=((ctrl/4)*(multi+1))-1;
for(j=k ;j<z; j++)
//fprintf(fp,"%x",byte[j]);
check=fifoed_avalon_uart_write(fp,byte/*Puntatore dati da Tx*/,25344);
but it seems i can transmit using (UART&#39;s light is switched on during TX)
...anyway, the received bytes don&#39;t seems the ones transmitted....What&#39;s up?
Thanks http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
does this IP still exist ? where can i find it ?
thanks.
If you need an UART with buffers, you can try YANU Uart from opencores. Its interface is compliant to Altera Avalon Interfaces and, as I remember, is supported in U-Boot (if you need a bootloader, too).
thanks ! I was searching the altera one for the sopc compatibility but yanu ip seems to have the same purpose. I will try it as soon as possible.
I use this IP instead :
http://www.alterawiki.com/wiki/fifoed_avalon_uart
it is based on altera_avalon_uart and is sopc ready. very fast to implement !!
Hi
I'm having issues with the fifoed avalon uart; I think it is a software issue but I am not sure.
I previously posted here
http://www.alteraforum.com/forum/sho...721#post181721
thanks.
Hey fates would you mind explaining how you got it to work?
I'm not having much luck with my own attempts.
