12606 Discussions
nios2-download -g zImage ERROR!!!!!
Hi All !
I did step by step guide by Wiki .
+ I build success kernel and application (hello)
+ but I have error when download kernel into board !!!
nios2-download -g zImage ---> this is message
uClinux/Nios II
Altera Nios II support © 2004 Microtronix Datacom Ltd.
Built 1 zonelists
Kernel command line:
PID hash table entries: 128 (order: 7, 512 bytes)
Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Memory available: 14868k/16384k RAM, 0k/0k ROM (1189k kernel code, 169k data)
Mount-cache hash table entries: 512
NET: Registered protocol family 16
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 1024 (order: 0, 4096 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP reno registered
io scheduler noop registered
io scheduler deadline registered (default)
Serial: JTAG UART driver $Revision: 1.1 $
ttyJ0 at MMIO 0x80801080 (irq = 2) is a jtag_uart
TCP bic registered
NET: Registered protocol family 17
no filesystem could mount root, tried:
kernel panic - not syncing: vfs: unable to mount root fs on unknown-block(0,0)
Thanks for help !
whenever you updated the kernel or romfs,
you have to run "make" and "make linux image" again.
--- Quote Start ---
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19323)
--- quote end ---
--- Quote End ---
Hi hippo
thank very much !
--- Quote Start ---
--- Quote Start ---
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19323)</div>
--- Quote End ---
Hi Hippo .
I try again "make" and "make linux image" but it still error !
--- Quote Start ---
--- Quote Start ---
--- Quote Start ---
--- Quote End ---
Hi Hippo .
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19331)</div>
--- Quote End ---
Please read the wiki,
http://nioswiki.jot.com/wikihome/operating...initramfsupdate (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/uclinuxdist/initramfsupdate
What&#39;s your error message?
Hello:
I have the same question,how did you resolve it?Please tell me.
Hi all,
I have the as error as you. Have you figure it out how to solve it ?
My output is :
root@F15:~# altera/12.1/nios2eds/bin/nios2-terminal
nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "USB-Blaster [8-1]", device 1, instance 0
nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
Linux version 3.7.0-01377-g1061bd7-dirty (root@F15) (gcc version 4.1.2)# 30 Fri Apr 19 12:09:10 EEST 2013
bootconsole [early0] enabled
early_console initialized at 0xe8001440
On node 0 totalpages: 32768
free_area_init_node: node 0, pgdat c02faac0, node_mem_map c03108a0
DMA zone: 256 pages used for memmap
DMA zone: 0 pages reserved
DMA zone: 32512 pages, LIFO batch:7
pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
pcpu-alloc: [0] 0
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory available: 126776k/3130k RAM (2387k kernel code, 743k data)
NR_IRQS:64
Calibrating delay loop... 18.94 BogoMIPS (lpj=9472)
pid_max: default: 32768 minimum: 301
bio: create slab <bio-0> at 0
Switching to clocksource timer
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP: reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 247
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
io scheduler cfq registered (default)
ttyAL0 at MMIO 0x8001400 (irq = 2) is a Altera UART
ttyJ0 at MMIO 0x8001440 (irq = 1) is a Altera JTAG UART
console [ttyJ0] enabled, bootconsole disabled
mousedev: PS/2 mouse device common for all mice
TCP: cubic registered
List of all partitions:
No filesystem could mount root, tried:
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
Any help is greatly appreciated.
Cem
If you are using the MMU and you've generated a *.dts file to be linked then I'd bet that your sopc2dts has some entries that need to be tweeked. If there are unknown entries then you need to fix those first.
--- Quote Start ---
--- Quote End ---
Thanks for a reply. Yes, i trying to use the MMU. So i did exactly as you said. But dont know how to fix *.dts file. Dts files is written below. Could you please check it and tell me what wrong is ?
root@F15:~/luclinux/sopc2dts# cat onur.dts
* This devicetree is generated by sopc2dts on Fri Apr 19 16:30:38 EEST 2013
* Sopc2dts is written by Walter Goossens <waltergoossens@home.nl
* in cooperation with the nios2 community <Nios2-dev@sopc.et.ntust.edu.tw
/dts-v1/;
model = "ALTR,onur";
compatible = "ALTR,onur";
# address-cells = < 1 >;
# size-cells = < 1 >;
cpus {
# size-cells = < 0 >;
cpu: cpu@0x0 {
device_type = "cpu";
compatible = "ALTR,nios2-12.1";
reg = < 0x00000000 >;
interrupt-controller;
# interrupt-cells = < 1 >;
clock-frequency = < 50000000 >; /* embeddedsw.CMacro.CPU_FREQ type NUMBER */
dcache-line-size = < 32 >; /* embeddedsw.CMacro.DCACHE_LINE_SIZE type NUMBER */
icache-line-size = < 32 >; /* embeddedsw.CMacro.ICACHE_LINE_SIZE type NUMBER */
dcache-size = < 2048 >; /* embeddedsw.CMacro.DCACHE_SIZE type NUMBER */
icache-size = < 4096 >; /* embeddedsw.CMacro.ICACHE_SIZE type NUMBER */
ALTR,implementation = "fast"; /* embeddedsw.CMacro.CPU_IMPLEMENTATION type STRING*/
ALTR,pid-num-bits = < 8 >; /* embeddedsw.CMacro.PROCESS_ID_NUM_BITS type NUMBER */
ALTR,tlb-num-ways = < 16 >; /* embeddedsw.CMacro.TLB_NUM_WAYS type NUMBER */
ALTR,tlb-num-entries = < 256 >; /* embeddedsw.CMacro.TLB_NUM_ENTRIES type NUMBER */
ALTR,tlb-ptr-sz = < 8 >; /* embeddedsw.CMacro.TLB_PTR_SZ type NUMBER */
ALTR,has-mul; /* embeddedsw.CMacro.HARDWARE_MULTIPLY_PRESENT type NUMBER*/
ALTR,reset-addr = < 0xc0000000 >; /* embeddedsw.CMacro.RESET_ADDR type NUMBER */
ALTR,fast-tlb-miss-addr = < 0xc8001000 >; /* embeddedsw.CMacro.FAST_TLB_MISS_EXCEPTION_ADDR type NUMBER */
ALTR,exception-addr = < 0xc0000020 >; /* embeddedsw.CMacro.EXCEPTION_ADDR type NUMBER */
}; //end cpu@0x0 (cpu)
}; //end cpus
memory@0 {
device_type = "memory";
reg = < 0x08001000 0x00000400
0x00000000 0x08000000 >;
}; //end memory@0
sopc@0 {
device_type = "soc";
ranges;
compatible = "ALTR,avalon", "simple-bus";
bus-frequency = < 50000000 >;
jtag: serial@0x8001440 {
compatible = "ALTR,juart-12.1", "ALTR,juart-1.0";
reg = < 0x08001440 0x00000008 >;
interrupt-parent = < &cpu >;
interrupts = < 1 >;
}; //end serial@0x8001440 (jtag)
timer: timer@0x8001420 {
compatible = "ALTR,timer-12.1", "ALTR,timer-1.0";
reg = < 0x08001420 0x00000020 >;
interrupts = < 0 >;
}; //end timer@0x8001420 (timer)
}; //end sopc@0
chosen {
bootargs = "debug console=ttyJ0,115200";
}; //end chosen
}; //end /
Yes i did as you said. But dont know how to fix .dts file. So i put here mine. Could you check and tell me what wrong is ?
/dts-v1/;
cpus {
cpu: cpu@0x0 {
}; //end cpus
memory@0 {
}; //end memory@0
sopc@0 {
ranges;
interrupts = < 1 >;
interrupts = < 0 >;
}; //end sopc@0
chosen {
}; //end chosen
}; //end /
--- Quote Start ---
--- Quote End ---
As you said i am using MMU. But it seem no unknown entries in dts files. How to understand and fix it ? If you need anything related .qsys design, please let me know.
/dts-v1/;
cpus {
cpu: cpu@0x0 {
}; //end cpus
memory@0 {
}; //end memory@0
sopc@0 {
ranges;
interrupts = < 1 >;
interrupts = < 0 >;
}; //end sopc@0
chosen {
}; //end chosen
}; //end /
--- Quote Start ---
--- Quote End ---
Yes i am trying to use MMU and i've generated .dts file to be linked. But i am not sure how to fix dts file. Please help me.
My dts file includes:
/dts-v1/;
cpus {
cpu: cpu@0x0 {
}; //end cpus
memory@0 {
}; //end memory@0
sopc@0 {
ranges;
interrupts = < 1 >;
interrupts = < 0 >;
}; //end sopc@0
chosen {
}; //end chosen
}; //end /
