12606 Discussions
u-boot v2016.03 working for anyone?
I have two boards - a de0_nano_soc and a sockit. Neither works with a u-boot v2016.03 build.
Is anybody out there using these eval boards able to successfully build & run u-boot?
On both cards, the u-boot-with-spl.sfp (includes SPL, uboot.img, dtb all in one) I generate either
doesn't boot at all, or boots sporadically, failing on memory calibration.
Here is one example:
U-Boot SPL 2016.03 (Mar 16 2016 - 08:27:20)
drivers/ddr/altera/sequencer.c: Preparing to start memory calibration
drivers/ddr/altera/sequencer.c: CALIBRATION FAILED
drivers/ddr/altera/sequencer.c: Calibration complete
SDRAM calibration failed.
### ERROR# ## Please RESET the board# ##
drivers/ddr/altera/sequencer.c: CALIBRATION PASSED
Trying to boot from MMC
U-Boot 2016.03 (Mar 16 2016 - 08:27:20 -0700)
CPU: Altera SoCFPGA Platform
FPGA: Altera Cyclone V, SE/A4 or SX/C4, version 0x0
BOOT: SD/MMC Internal Transceiver (3.0V)
Watchdog enabled
I2C: ready
DRAM: 1 GiB
MMC: dwmmc0@ff704000: 0
In: serial
Out: serial
Err: serial
Model: Terasic DE0-Nano(Atlas)
Net:
Error: ethernet@ff702000 address not set.
No ethernet found.
Hit any key to stop autoboot: 0
Once started, USB never works - even though the feature has been (seemingly) properly configured
=> usb start
starting USB...
USB0: Core Release: 2.93a
dwc_otg_core_host_init: Timeout!
scanning bus 0 for devices... 1 USB Device(s) found
If anyone has solved these problems, please share!
Thanks!
--George
