Processors
14573 Discussions
4770k unable to oc
mprov
Hi my rig is Motherboard z87 mpower cpu intel 4770k ram kingston hyper x blu 4x4 gpu gigabyte 770 4gb ssd kingston SSDnow psu corsair Gs800....I am trying to oc the cpu with no luck at all .Ive tryied all possible adjustments i found on the web....I had it for a month at 4.2 ghz 1265V but it wasnt so stable the i tryied to raise vcore with no luck and the i tryied with lower volts again with no luck ....volts i tryied for 4.2 an 4.3 :From 1.2 to 1.275 and no luck...I tryied to adjust cpu ring ratio and volts again it was unstable.i even try this guidehttp://www.overclockersclub.com/guides/overclock_intel_4770k_guide/2.htm http://www.overclockersclub.com/guides/overclock_intel_4770k_guide/2.htm and thishttp://www.overclock.net/t/1411077/haswell-overclocking-guide-with-statistics http://www.overclock.net/t/1411077/haswell-overclocking-guide-with-statistics ...I set up the same adjustments for 4.2 and 4.4 with the guide and nothing...I am starting to believe tha my cpu is defective or its somethink wrong with my motherboard...The Bluescreens i receive are whea_uncorectable_error the error code is : 0x00000124 (0x0000000000000000, 0xffffe00004173028, 0x00000000bf800000, 0x0000000000000124) at most times...I dont know what else to do.can someone help me please?
Silvia_L_Intel1
Hello Mariosprob, thanks for informing us about this behavior. We have seen this before, and it could be related to a BIOS support on your motherboard.
I recommend you to check with Mpower if there is a BIOS update you may need to install on the motherboard.
If they confirm there is none, you more than welcome to contact our warranty department so they can help you replacing the processor.
http://www.intel.com/p/en_US/support/contactsupport http://www.intel.com/p/en_US/support/contactsupport
Please keep in mind that even though Intel makes unlocked and Extreme Series processors that are strong enough to handle customizations, Intel doesn't recommend overclocking any of their internal components such as memory, video or CPU. I'm afraid that it would be under your own risk since there is no warranty support for that practice.
mprov
My Bios is up to date ...There are no other update to do....And i understand that if the cpu works perfectly in stocks i cannot replace it..The thing i want to know is if my cpu is not strong enough to handle customizations or i am doing something wrong with the bios adjustments...My previous cpu was intel 2500k and it was able to oc with no problems...
Silvia_L_Intel1
I'm sorry about this situation but please note that the operation of any Intel-manufactured product outside the published specifications can result in data corruption and unreliable system behavior. It will shorten the life of your product, void the warranty of your processor and possibly other devices installed in the computer. Therefore we are precluded to provide any recommendation about your inquiry.
