Processors
14552 Discussions
Accidental overvoltage, 4790k
GVeng
Hello to the people.
I recently bought a 4790k. I checked the voltage with my ASUS z97 pro gamer and it was 1.302 by default giving me some high temps at FPU stress. So I wanted to lower it to 1.18. But (stupid clumsy head) accidentally I set it to 1.8. I saved bios, rebooted, and a message at post said: Overvoltage warning!!. Immediately I entered BIOS, changed my voltage to 1.18 hit F10 and enter, in like 10 seconds. Do you think I damaged my chip? It costed me a fortune, and I'm so happy with it... Please no trolling
EstebanA_C_Intel
Hello venge:
Thank you for contacting Intel Communities.
I understand that you changed the voltage of your CPU at BIOS level and you would like to know if it may have been affected.
If you would like to test your processor, there is a tool from Intel called Intel® Processor Diagnostic Tool; you can run its tests to see if any component of your CPU has been affected.
If this happened for a short period of time, your CPU should not have been harmed or damaged.
Most stress test would cause high temps in your processor, it would take it to its limits and higher which would be the reason why overheating may be present.
The TDP for the Intel® Core™ i7-4790K Processor is 74.04°C, any temperature under that would be secure.
Intel® Processor Diagnostic Tool links:
64-bit: https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool-64-bit- Download Intel® Processor Diagnostic Tool (64-bit)
32-bit: https://downloadcenter.intel.com/download/19791/Intel-Processor-Diagnostic-Tool-32-bit- Download Intel® Processor Diagnostic Tool (32-bit)
More information about Intel® Core™ i7-4790K overheating:
Do not hesitate to advise us if you have any additional questions or concerns.
Esteban C
Cesar_B_Intel
Hello Venge,
Were you able to run the https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool-64-bit- Intel® Processor Diagnostic Tool?
Please post your results.
Caesar B_Intel.
