Processors
14550 Discussions
LGA 2066 socket
GMona1
Can one insert an LGA 2066 socket into common breadboard?
Hello SlicedBread,
I understand that you would like to insert an LGA 2066 socket into a breadboard.
Regarding this I would like to have more information about what is intended to do so this way I can check whether it will be possible or not.
David V
GMona1
Greetings David,
Thank-you for responding.
I like to build and maintain things.
Hello SlicedBread,
Thank you for your response,
In this case, to get the most accurate information and get the answer to your question regarding the breadboard and the socket I would recommend you to register and login to this website:
https://www.intel.com/content/www/us/en/design/resource-design-center.html https://www.intel.com/content/www/us/en/design/resource-design-center.html
David V
GMona1
Hi David,
This new link sends me to a blank page.
Hello SlicedBread,
I was directing you to our resource & design center, I have tried the link and it is indeed working. Perhaps trying in a different browser may work?
Let me give you another link just in case:
https://www.intel.com/content/www/us/en/design/resource-design-center.html Intel ® Resource & Design center
David V
GMona1
Hi David,
I managed to get it working by cutting & pasting the text directly into the browser's address bar.
Unfortunately, the resource & design center requires one to possess a company email address. This I do not have.
Hello SlicedBread,
I was verifying what you mentioned and in fact if you do not have a company e-mail that is fine, you can actually use your personal one as well there would not be any problem. As soon as you are done with the registration you need to get to the support area and they will provide you with the most accurate answer.
David V
Hello SlicedBread,
I am following up with your case and see that we have not heard back from you.
If you need more assistance do not hesitate to reply.
David V
