Processors
14554 Discussions
My 4770 missing 2 capacitors. Shoud i be worried?
VGorc
Recently i noticed that my processor missing 2 capacitors. Inspite the fact that it's working just fine a little later i've become nervous and paranoid about it. Is it going to last long? What are those capacitors responsible for? Can you give me their rates so i can solder similar there?
IUman
Hello ViktorGorchev,
Thank you for joining the Intel communities.
If your processor is working fine there is nothing to worry about it.
At this point if your system were missing two capacitors I don't think your system will start, if you assemble the system and you're able to access Windows the processor is working fine.
You can run the https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool-64-bit- Intel® Processor Diagnostic Tool to see if there are any errors detected, if pass it is fine.
Regards!
