Processors
16320 Discussions
PCH Fail on NUC D54250WYKH1 D54250WYB Board
JMitc6
I've had a recurring, intermittent problem with the cursor locking in place at the top middle of my monitor, blinking at about 2Hz. Updating drives, rebooting, etc. haven't solved the problem.
Today I downloaded and ran the Intel Processor Diagnostic Tool. It reported the PCH test failed.
System Information
NUC
D54250WYKH1
D54250WYB Board
Processor http://community.futuremark.com/hardware/cpu/Intel+Core+i5-4250U/review Intel Core i5-4250U
Windows 10 - up to date
Intel Driver update tool says all drivers up to date
Windows Memory test says no problems.
I found a suggestion for a fix at Tom's Hardware, but I couldn't get at the motherboard battery to try it.
http://www.tomshardware.com/answers/id-3261610/intel-diagnostic-tool-pch-fail.html Intel diagnostic tool PCH fail. - [Solved] - CPUs
Questions:
1) Is my blinking cursor problem likely to be caused by the PCH failure problem?
2) What can I do to fix the PCH failure?
Text of Failure message
PCH Test Failed
CPU1
PCH Test
Module Version: 1.0.10.64b.W
Start Time: Sat May 27 19:10:25 2017
Test Result - FAIL
LPC deviceID = 0x9c43
Chipset : Intel(R) 8 Series Chipset
Chipset Stepping : C1
Error while retrieving SATA Device Information from OS.
Platform Controller Hub Test Failed!!!
End Time: Sat May 27 19:10:25 2017
Total Time: seconds: 0
Hello aengineer,
Thank you for contacting the Intel community.
Have you tried with different mouse?
Try running Windows update; I have seen some customer solving the PCH fail result by reinstalling the https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool Intel® Processor Diagnostic Tool.
It is hard to determine if the PCH fail result is causing this problem, this curser issue can also be cause by the RAM, have you tried reseating the RAM or if you have two RAMs installed try one at a time.
I hope this can help.
Ivan U.
JMitc6
  • Different mouse - no luck
  • Windows update - no luck
  • Intel Processor Diagnostic Tool - Installed after cursor problem appeared - did not affect it. Haven't installed it again.
  • RAM - ran MS diagnostic - no errors; reseated - no improvement
Thank you for the information aengineer, being that the case, I suggest you to http://www.intel.com/content/www/us/en/support/contact-support.html# @2 contact support to get a replacement for the unit.
Ivan U.
JMitc6
I tried to find support at Intel after reading this latest reply, but was unsuccessful. The specs for my unit says "Status End of Interactive Support." Does that mean no support at all?
Hello ngineer,
The unit is end of interactive support but Intel provides three years warranty from the moment the purchase is made.
The support is working right now so you can either create a online service request or you can do live chat.
http://www.intel.com/content/www/us/en/support/contact-support.html# @5 http://www.intel.com/content/www/us/en/support/contact-support.html# @5
Please let me know if you can access the website.
Ivan U.
JMitc6
I tried repeatedly to access the website. I sign in with no problem, but when I attempt to create a support ticket it tells me that it doesn't recognize the product, despite providing the correct Stocking ID. My info is:
G6YK41500FBL
MAC C03FD564ACD3
H26245-102 - Stocking ID/Part #
D54250WYKH1 Kit
Purchased 7/10/2014 from Amazon
Jim MItchell
Hello aengineer,
I have sent you a private message for warranty information.
Ivan U.
