I have a very simple design in Quartus Web Pack ver 11.0 , and with it i have Modelsim-Altera Starter ver 6.6d. I get these error messages "vsim-19" when i do rtl-level simulation .
"failed to access library tb_xxx st tb_xxx" I used the same vhdl files and run the simulation in Modelsim ver 6.2 SE and i see results as expected ??? I have checked the mapping of lib using vmap it is ok . What is the problem ??? </SPAN>Link Copied
From your picture, there is no tb_ezusb library.
i have a simple counter design with the same tb setup and its RTL simulation works.
