Server Products
Data Center Products including boards, integrated systems, RAID Storage, and Intel® Xeon® Processors
5016 Discussions
Compatible Intel Dual Port PCIe NIC for Dell T20 server
DA4
I'm searching for Intel PCI express NIC Dual port for Dell Poweredge T20 server
Intel(R) Xeon(R) CPU E3-1225 v3 @ 3.20GHz
Which model of Intel dual port PCIe NIC compatible with this server.
Hello Deepak11,
I understand that you are looking for an Intel Dual Port PCIe NIC that is compatible with the Dell PowerEdge T30 Server.
Regarding this, the best recommendation I can give you is to get in contact with Dell Support since they should manage and know what hardware is compatible with the system you currently have.
David V.
DA4
Thanks David,
Dell support suggesting broadcom NIC.
Hello Deepak11
I was checking your case and would like to know if you need further help. If so, please do not hesitate in replying back.
Leonardo C.
DA4
Yes Leonardo,
Intel PCI Express i350 T2 2 Port 100/1000
is this model compatible with my Dell T20 server ? & I need better Virtualization support also.
Deepak A.
Hello Deepak11,
Regarding compatibility with your Dell Server the best option is always to ask the manufacturer as they know the specifications of the system and can more accurately tell you if a NIC is compatible or not.
David V
DA4
