Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4785 Discussions
Intel® Server Board S1200KP Startup problem
Hi to All,
I recently build a mini-ITX Server based on Intel® Server Board S1200KP coupled with,
Intel Core i3 2100T
160GB 320 Series SSD
Silverstone ST45SF SFX Power supply (450Watt)
Kingston 2*4GB DDR3-1333MHz Non-ECC Ram KINGSTON KVR1333D3N9/4G Modules.
My Problem is that the board is stucking at Logo Screen with bios initialization code of EB.
I don't know where the problem lies to?
Can you be of some assistance?
Edward_Z_Intel
POST code EB means "Calling Legacy Option ROMs". Do you have any add-in card attached? Remove all devices and leave only PSU, CPU and memory, and boot the system. If you hit during POST, can you go to the BIOS setup screen?
I do not have any add-in card attached. I am not able to press F2 to enter bios either... i am stuck to logo screen.
As i said before the only device i have attached is the ssd, exept cpu memory and psu...
My problem lied on a USB DVD-RW that needed 2 USB ports for operating ok. Since i plaggued it in my motherboard got frozen....and when removing it, all was fine again.
I had to install my operating System (SBS 2011 Essentials) using a USB flash drive for booting.
All is well know.
