Server Products
4787 Discussions
Intel Server board S2600CW2SR
RPads
I have made a server setup with 2 xeon e5 2620-v4 processor.
my pc starts but stuck at boot. USB ports are not working as keyboard and mouse are not working. screen stuck at
"Warning: This server is running factory firmware.
A software update is required.
Please load the latest system update package(SUP)
to unable the latest security, quality and performance capabilities.
Hello ravindrao5 ,
Can you perform the following steps in order to update the BIOS?
  1. Download the latest firmware for Extensible Firmware Interface* (EFI*) from the support site.
  2. Unzip the package and copy all files to a folder on a USB device.
  3. Insert the USB device to the server/workstation USB port.
  4. Boot the server to the EFI shell.
  5. Run the map -r command in EFI shell to map USB device.
  6. Run the fs0: command to change folder to USB device. USB device can also map to fs1:. The number of the fs# is dependent on the result of the map -r command.
  7. Change the folder to the folder storing the firmware package.
  8. Run the startup.nsh command to start updating all the firmware and BIOS.
You can download the software by accessing this link:
https://downloadcenter.intel.com/download/28004/?product=88276
Charlie_Intel
Hello ravindrao5,
We are wondering if you were able to perform the troubleshooting steps?
Charlie_Intel
Hello ravindrao5,
We are wondering if you need further assistance?
Charlie_Intel
RPads
Does this mother board supports non ecc ram?
Hello ravindrao5,
This board only compatible with ECC memory.
Charlie_Intel
Hello ravindrao5,
Charlie_Intel
Hello ravindrao5,
We are wondering if you have further questions?
Charlie_Intel
RPads
Hello ravindrao5,
You are welcome if you have further questions do not hesitate to contact us back.
Charlie_Intel
