Software Archive
Read-only legacy content
17060 Discussions
False Positive?
bayesiam_matrix
Hi.
Allcation site at,
n = _num_vect * _dim;
v = new Vect_d[_num_vect]; <<<
v[0].d = new double;
v[0].Dim(dim);
for ( i = 1; i < _num_vect; i++){
v.d = &v[0].d[_dim*i];
v.Dim(_dim);
caused error at,
for_p( _vects.Vectors() ){
Pred( _vects.v
dose iterror?
best regurd.
Ravi_V_Intel
Can you please provide some more information:
* Which Intel tool (including version of the tool) were you trying to use when the error happened?
* Can you please provide a small self-contained code snippet which demonstrates the problem so that I can attempt to reproduce the issue or pass it along to the right people? Also, please provide steps to reproduce the issue.
Thank you!
Ravi
bayesiam_matrix
Thank you for your attention.
My Intel tool is Inter Parallel Inspector Update 2.
I will send you an extracted package that causes uninitialized memory access.
Thank You very mutch.
Yamane
