Software Archive
Read-only legacy content
License not available, 2015 to 2016 upgrade cmplr, Err (-5,414)
mguy44
I receive a mail with downloading links for upgrading Intel's products on our cluster (Fortran and C++ compilers, MKL, Intel's MPI). As we have 2015 versions installed, so it's an upgrade to 2016's versions.
I download the packages (Fortran, C++ compilers, ...)
I ask for a licence file in the right place. I put it on the cluster, give the absolute path during installation of the packages.
If I check the 2016's fortran compiler, I get an error message :
.../intel/compilers_and_libraries_2016.0.109/linux/bin/intel64/ifort --version
Error: A license for Comp-FL is not available (-5,414).
License file(s) used were (in this order):
    1.  Trusted Storage
**  2.  /opt/intel/licenses/[...]_USE_SERVER.lic
**  3.  /opt/intel/licenses/COM_L__CPPFOR_[...] /lic
**  4.  /opt/intel/licenses/USE_SERVER.lic
**  5.  /opt/intel/licenses/server.lic
The new licence file (COM_L__CPPFOR_...) is in this list, the serial number inside it corresponds to the upgrade's SN. So what's wrong with it ?
Thank you for your help.
Older versions of compilers are still working with their own licence file.
   Guy.
Hubert_H_Intel
Guy,
In your /opt/intel/licenses paths there are 3 (conflicting?) license files.
On client machines there should be only 1 license file OR the environment variable INTEL_LICENSE_FILE pointing to the license server.
The USE_SERVER.lic license on the client machines shall be of format:
   SERVER <servername> ANY <port>
   USE_SERVER
The enviornment variable shall be:
   export INTEL_LICENSE_FILE=<port>@<servername>
Have you sourced the compiler environemnt prior to invokation of ifort?
   source <installdir>/compilers_and_libraries_2016.0.109/linux/bin/compilervars.sh intel64
If this doesn't help, please create a debug log as follows (after sourcing):
   export INTEL_LMD_DEBUG=1
   ifort -V &>LMD.log
and upload it to this forum thread.
Regards, Hubert.
mguy44
Hello Hubert,
Thank you for your answer.
I want to change the installdir to be on a shared FS instead on a private FS. So, this may interfere with the installation of the upgrade.
Next, I look at the env. var. INTEL_LICENSE_FILE and its value is not what you write :
/opt/intel/licenses:/.../users/<login>/intel/licenses:/Users/Shared/Library/Application Support/Intel/Licenses
The [...]_USE_SERVER.lic has the right format
I have sourced the file compilervars.sh . The problem still occurs.
As there are SN and other informations in the output, I'll send the output in a private message.
   Guy.
mguy44
Hello Hubert,
Thank you for your help through private messages.
Now It works fine : I have changed the license file and force its re-reading.
   Guy.
