Bonjour,
Du jour au lendemain, je n'ai plus eu aucun réseau wifi :
Celle ci est bien activé : (mais pas connecté)
Aidez moi,
Merci
Shutdown, unplug power cable, wait 5 minutes and then reconnect. Does the WLAN come back when you boot into Windows?
Oui,déjà fait rien n'y fait (trad this message)
The latest drivers for this card can be downloaded from here: and here: . Please manually download and install these drivers. Use this process:
- Download the latest Bluetooth and WiFi drivers for your adapter. Here are links to these drivers:
- Disable Internet access. Unplug Ethernet cable and/or disable wireless. Keep disabled until told to re-enable.
- From Programs and Features applet or from Apps & Features in Windows Settings, uninstall any instances of the Intel PROSet/Wireless Software and Intel Wireless Bluetooth. When prompted, choose to "Discard Settings".
- In Device Manager > Network Adapters, right click on your Intel Dual Band Wireless-AC 7265 and uninstall it. Make sure to mark the option to "Delete the driver software for this device."
- Clear out your temporary files using the Windows Clean Disk tool.
- Manually shutdown and reboot your computer.
- Install the drivers downloaded in step one. Install Bluetooth first, followed by Wireless.
- Enable Internet access.
- Test.
Hope this helps,
Topic Options
