Wireless
7447 Discussions
Intermittent connectivity on AC-3165 wireless adapter
BSund1
I am having connectivity issues on TWO laptops (different brands HP and Lenovo) using the same adapter with Windows 10 Home 64 bit as the OS. I have a p50 laptop with Win7 that works FINE. The HP used to work well until a windows update seemingly caused issues. I can get a few really good speed tests at speedtest.net and then I'll either get a latency error or a very slow (0.84Mb/s) download speed. Most of my download speed on the test were between 24.0 and 29.0 Mb/s. I have tried many different things including updating wireless driver, rolling back the driver, etc. to no avail. Please advise. Just an FYI - the HP is a year old and the Lenovo is two weeks old. Thanks.
Hello BrentS,
Thanks for posting. We understand that you're experiencing wireless download speed issues after updating to the latest Windows 10* version.
In order to better assist you, we would like to gather some more information. On at least one of the systems, please download and run the https://downloadcenter.intel.com/download/27330/Intel-Solid-State-Drive-Toolbox%3Fproduct%3D94434 Intel® System Support Utility (while connected to your network) and share the resulting report with us. Additionally, please attach the WLAN report as well. Here's how to get it:
  1. In the search box on the taskbar, type Command prompt, press and hold (or right-click) Command prompt, and then select Run as administrator > Yes.
  2. At the command prompt, type netsh wlan show wlanreport.
Eugenio F.
BSund1
How do I insert the files that were generated with the above? I have them on my computer. Thanks.
Hello BrentS,
To attach a file, you must click the "attach" option at the bottom right corner of the response box.
Eugenio F.
BSund1
Here are the files requested. Thank you!
Hello BrentS,
Thanks for the files.
Your wireless connection rate is just 6 Mbps at full signal strength on the 5 GHz band, which is quite low. Most routers can transmit in two bands. Do you get similar results if you switch to the 2.4 GHz band?
We would like to approach the wireless adapter first. Please try a clean wireless driver installation using both he Intel generic driver and the driver provided by the OEM (Original Equipment Manufacturer) for comparison.
Here you can find detailed instructions on how to perform a clean drivers installation and the links to download them:
- https://www.intel.com/content/www/us/en/support/articles/000022173/network-and-i-o/wireless-networking.html Clean Installation of Wireless Drivers
- https://www.intel.com/content/www/us/en/support/articles/000005559/network-and-i-o/wireless-networking.html Latest Driver for Your Intel® Wireless Adapter
- https://pcsupport.lenovo.com/hn/en/products/laptops-and-netbooks/300-series/320-17ikb/80xm/downloads Lenovo 80XM* Drivers
NOTE: Links to third party sites are being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
Please let us know the results.
Eugenio F.
BSund1
I am still having the same issue. Please find updated files. Thank you.
Hello BrentS,
Thanks for your reply.
Based on the new Intel® SSU and WLAN reports, your connection rate has improved to 390 Mbps.
Please let us know the following:
- When you say there are still issues, are you referring to intermittent connectivity or download speed?
- Do you get similar results if you connect to 2.4 GHz band on the same router?
- Is the issue reproducible in other networks?
Eugenio F.
BSund1
I am having the same intermittent download speeds. I would get a download rate of 25-26Mbps on speedtest.net. Then I will get one that is 4-5Mbps. Also, I had three laptop all exhibit the same characteristics. One of those laptops shows no issues on my work network. Not sure how or if I have tried to connect solely to the 2.4Ghz network. Please advise. Thanks.
Hello BrentS,
Most dual band routers allow you to configure two different SSID, one for 5GHz and another one for 2.4GHz. You might see two different networks coming from the same router.
As the issue seems limited to this network, you may try the following:
- Make sure your router firmware is up to date.
- Toggle off QoS (Quality of Service) rules on the router or reset it to factory settings (you'll have to set your network SSID again).
- Still on the router, test https://www.extremetech.com/computing/179344-how-to-boost-your-wifi-speed-by-choosing-the-right-channel switching channels. For 2.4GHz the recommended channels are 1,6 and 11 as they do not overlap with other channels. 5GHz channels are further apart than 2.4GHz and shouldn't interfere with each other, but you may switch it for testing.
Eugenio F.
Hello BrentS,
We haven't heard from you in the last few days. Did you have the chance to test using different settings on your router?
Eugenio F.
BSund1
This is an ATT modem/router that has limited ability to change certain aspects of the network. I had ATT in over the weekend and they put in a different brand, but I still seem to be having bottlenecks or slow downs. There are many devices in my home that are wireless, but up until recently I've never had an issue. I have messed with QoS before, but that hasn't seemed to do much for me. Are there any settings on the adapter that may help keep a more constant speed? Thanks for your help.
Hello BrentS,
From the adapter side, there are recommended advanced settings for better performance:
- https://www.intel.com/content/www/us/en/support/articles/000024678/network-and-i-o/wireless-networking.html Recommended Settings for 802.11ac Connectivity
Even though the article doesn't mention it, we recommend setting the channel width for 2,4 GHz band to 20 MHz only, and the roaming aggressiveness as lowest.
Other than that, please make sure Windows* https://docs.microsoft.com/en-us/windows-hardware/design/device-experiences/advanced-power-settings advanced power settings are set to maximum performance for wireless adapter.
Eugenio F.
LGasp
Good day,
I have a Dell 5567 notebook, it has an Intel AC3165 Wi-Fi board. Internet download speed does not reach 4Mb. At home I have another old HP notebook, which I usually download at a speed of 25Mb. Obviously, the two connected through Wi-Fi.
I have tried everything to correct the problem without finding success. I have contacted Dell technical support, which gave me remote assistance, installed and uninstalled the drivers, without success of having found the solution. I have changed the configuration of the Wi-Fi board, having gone through all the possible configurations, and always obtaining the same results.
What version of Windows do you have? In my opinion the problem started after a Windows update.
Could someone solve it? In what way?
LGasp
BrentS
Could you solve it?
BSund1
lucian: I have Windows 10. I have better performance on my windows 7 laptop. I believe some of this to be a Windows 10 issue possibly. What version of Windows do you have?
BrentS
LGasp
BrentS
Thanks for your answer. I have Windows 10 Home. In my opinion, the problem started after a Windows 10 update.
What speed do you have with Windows 7?
Do you have Windows 7 on that same PC?
Have you managed to improve the speed in any way? I have tried for several days without success.
BSund1
I have windows 7 pro on my work laptop and I see pretty normal speeds with U-verse internet. With my two win 10 laptops I get sporadic speed drops. One test will be 28M and the next will be 3-4M or less. Haven't had time to play lately but I tried messing with settings and just got another different router from att and it still has issues. I feel it started after some recent win 10 updates as one of those computers was fine until about 2-3 months ago. Not entirely sure tho!!!
Hello BrentS and lucianogaspari,
Have you tried installing the recently released https://www.intel.com/content/www/us/en/support/articles/000005559/network-and-i-o/wireless-networking.html Intel® PROSet/Wireless Software and Drivers version 20.30.1? This could help correct some issues on Windows 10*.
Eugenio F.
BSund1
I just downloaded them and I will try to install the drivers tonight to see if it helps. I believe it to be a Win 10 issue only because I rarely have any issues streaming Netflix or Hulu on my network. Thanks.
Brent
LGasp
I installed the new driver that you indicate to me. The results are the same, a very slow download speed. What other tests do you recommend me to do to find the solution to this problem?
