Wireless
8663 Discussions
Why won't the Intel Network 7260 HMWG AC wifi card work in my Dell XPS 15?
TKett
I recently purchased two Intel Network 7260 HMWG AC wifi cards to replace the existing cards in my two laptops (Dell XPS 15 and XPS 17). After installation, both computers give me an error message stating, "A physical WiFi adapter is not installed." I tried installing both new cards, independently, in both computers. Same results all around. Neither computer will recognize either wifi card. I find it hard to believe I could have gotten TWO defective cards. Why won't my Dell laptops recognize these new cards?!?!?
tvete
Valued Contributor II
Dell only allows Dell branded cards on some of their models. You ought to get a dell wireless 1550 card rather than 7260
ASouz7
hello Gramps
Intel does not support Integration and that is when the original wireless card is replaced for another one. Please keep in mind that wireless hardware installation and use is subject to regulatory approval and the new adapter may not support local regulations. Only your system manufacturer is entitled to provide the list of validated and certified adapters that are compatible with your system, so for more information we recommend that you contact them directly. Furthermore, Intel(R) Wireless Adapters are meant to be professionally installed the OEM (Original Equipment Manufacturer) technicians on certified systems only as they customize the adapter and features may be added or removed, voltage alterations...etc. Please check the links below for more information on this subject.
http://www.intel.com/support/wireless/wlan/sb/CS-031167.htm http://www.intel.com/support/wireless/wlan/sb/CS-031167.htm
http://www.intel.com/support/wireless/wlan/sb/cs-011644.htm http://www.intel.com/support/wireless/wlan/sb/cs-011644.htm
On our best effort to assist you, we would like to offer the links below which are related to the Intel® Dual Band Wireless-AC 7260
http://www.intel.com/p/en_US/support/category/wireless/db-ac7260/trblsht Troubleshooting for the Intel® Dual Band Wireless-AC 7260
http://www.intel.com/support/wireless/sb/CS-030709.htm?wapkw=wifi+recommended+settings Wireless Networking — What are the Recommended Settings for 802.11n Connectivity?
Let us know if this information helped you.
