Problem with SOPC Builder
Hello
I got a problem with SOPC-Builder v5.0.
I made a new Project in Quartus II v5.0, and added NIOS II cpu, OnChip Memory and Jtag UART in SOPC Builder. When I click on the generate button, an error occurs. I tryed the same thing on another computer and it worked, unfortunately it does not work on my computer http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif I get the following error message:
Altera SOPC Builder Version 5.00 Build 168
Copyright © 1999-2005 Altera Corporation. All rights reserved.
# 2005.09.20 12:44:46 (*) mk_custom_sdk starting# 2005.09.20 12:44:46 (*) Reading project D:/lb1a/system.ptf.# 2005.09.20 12:44:47 (*) Finding all CPUs# 2005.09.20 12:44:47 (*) Finding all available components
no install.ptf file found at c:/altera/quartus50sp1/sopc_builder/bin/europa/europa_utils.pm line 1758.
Error in processing. System NOT successfully generated.
What can cause this problem and how to mend it??
Hi MrZol:
I also had this problem some tiem ago and I think it&#39;s due to strange characters in your Windows user name. So try to change your user name using only international characters(ie, no ó or &#39;e or things like this).
Good luck,
Luis
