12606 Discussions
Some problem when using the boa
Hi:
I have build uClinux system on the board (stratix 1s10), and wanna complete some remote-control via CGI function on boa. For example, control the LED from webbrowser.
First I create linux appliction project 'ledcontrol',compile ledcontrol.c to ledcontrol.exe with no problem.
Copy ledcontrol.exe to the httpd/cgi-bin/ folder.Then build this filesystem and upload.
And create a new index.html
When i call this address: http://target_board_ip/cgi-bin/ledcontrol.cgi (http://target_board_ip/cgi-bin/ledcontrol.cgi
there are no show page, no response to LED.
When i test from nios2-terminal,show info below:
# cd httpd/cgi-bin# ls helloworld  led_test    ledcontrol# ./ledcontrol HTTP/1.0 200 OK Content-type: text/html <html><title> NIOS II CGI testings </title> No Content-Length was sent with the POST request. </html>
I have searching the concern topic about boa and cgi in this board,like "How to use boa?" by sunclever.
I have done the same way, but can&#39;t let the cgi working right, no response to LED neither.
Can anyone give me some help~Thank you!
Best Regards!
Justin
Hi~!
Anyone here..? I need your help, this problem hasn&#39;t been fixed.http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
Thank you very much~!
Best Regards!
Justin
I&#39;ll give it a try today and see what happens. I&#39;ll let you know by today or tommorow.
Try taking a look at the following thread:
boa cgi support (http://www.niosforum.com/forum/index.php?act=st&f=18&t=1505&hl=cgi)
