VGA Component für NEEK
i just wanted to know whether a vga component for the NEEK exists?
D.
You can modify the one from DE2VGA example.
- Hippo
after some issues with the touch screen driver I would like to refer back on this topic.
As I assumed you refered to the de2vga components also used in frame buffer example on http://www.nioswiki.com/operatingsystems/uclinux/framebuffer (de2_vga.zip)
Could you provide me the source of the de2vga example if I'm wrong, please.
Further more could you please list the modifications/modified component settings I have to perform?
I would appreciate your help.
D
Yes, I mean the de2_vga.zip. The vga controller was posted on old niosforum.
On the other hand, there are video input/output core in sopc builder of quartus v9.1. I would suggest them for new design. Though I don't have time to try out myself.
- Hippo
Thank you for your fast reply!
I'm working with Quartus 9.0sp2. Target Board is NEEK.
Actually "Clocked Video Output/Input" (SOPCBuilder: Video and Image Processing -> IO -> Clocked Video Output) are included in Quartus 9.0sp2.
Did you mean this cores?
I wanted to extend the cIII standard system files (you posted under:
http://www.nioswiki.com/@api/deki/files/115/=neek_ocm_spi.zip
with a vga component and use it on NEEK.
1) Is it possible with 'modified' de2vga files and/or video output cores of quartus 9.1?
The controller you mentioned is that one http://forum.niosforum.com/forum/index.php?showtopic=3165
if I'm right.
2) Could you roughly point out the changes I have to consider if the extension with de2vga is possible on the mentioned system files?
D
Yes, it is in the 3165 post. You can copy the VGA_controller_component dir to your neek project's ip directory.
neek_ocm_spi/ip/VGA...
Then you can add it within sopc builder. Be sure to name it as "vga_controller_0". Connect master port to ddr sdram, and slave port to peripheral bus. You will need to modify the top level design to connect the video outputs.
- Hippo
Sorry for my bad knowledge, but I have two more questions:
1) Placed and connected the vga_controller into the sopc system.
What clock does the slave/master port of the vga_controller need? (Configured the controller: 1024x768 65 MHz)
2) Do I need further components like parts of the modified de2vga example?
I would like to keep you informed for potential questions.
D.
I need some help with error issues after trying to generate the system (SOPC Builder).
As stated above I integrated the vga controller into the standard cIII system and hit 'Generate' but an error states the following report:
error: one or more components could not be located (ddr_high_perf). check ip search path under tools->options... in sopc builder.
error: system generation failed.
I set the search path for the ddr_high_perf component to the proper IP folder where the component is located but the error will still appear.
Have you some advice on this problem?
Appreciate,
D
delete the db folder in your project directory and try again
Tried, but no success. The error message still appears.
Problem solved. Thanks.
Hi again,
I have a hard time to make the connections between the vga controller and the system design.
Could you please provide some help, like what connection I have to consider, which design file is involved, etc?
It also would be great if a ready-to-run system for NEEK (EP3C25) with this vga-controller already exists and you could present the source.
PS: Does the "Altera framebuffer support" under uClinux kernel configuration also support the vga output?
For some help, I'd be much obliged.
D.
